メインコンテンツにスキップ
EVGA x17 Disassembly and Cleaning
必要な工具と部品
  1. EVGA x17 Disassembly and Cleaning, Mouse: 手順 1、 1の画像 1
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Disassembly and Cleaning: 手順 2、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel
  3. EVGA x17 Disassembly and Cleaning: 手順 3、 1の画像 1
    • Remove the weight chamber cover and clean with a Q-tip or soft fabric.
  4. EVGA x17 Disassembly and Cleaning: 手順 4、 1の画像 1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
    • Use a Q-tip or soft fabric to clean the bottom panel.
  5. EVGA x17 Disassembly and Cleaning: 手順 5、 1の画像 1
    • Remove the 13 screws on the interior.
    • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
  6. EVGA x17 Disassembly and Cleaning: 手順 6、 2の画像 1 EVGA x17 Disassembly and Cleaning: 手順 6、 2の画像 2
    • Once all screws are removed, carefully slide the middle section out and clean with a Q–tip or soft fabric.
    • Clean the top panel with a Q-tip or soft fabric.
    • Optional: you can remove clickers as well and clean them.
    • Remove the smaller sized cross head screws from the piece labeled A29N001-C V1.0 RU 94V-0. Remove truss head tapping screws from the side of the mouse wheel.
    • Remove 4 screws from the piece labeled AZAC001-A V1.0.
  7. EVGA x17 Disassembly and Cleaning: 手順 8、 1の画像 1
    • Pull transistor from the side of the mouse wheel.
  8. EVGA x17 Disassembly and Cleaning: 手順 9、 1の画像 1
    • Carefully slide a spudger between the opaque plastic that holds the scroll wheel in place.
    • Pry the plastic away from the wheel, allowing for the scroll wheel to be removed.
  9. EVGA x17 Disassembly and Cleaning: 手順 10、 2の画像 1 EVGA x17 Disassembly and Cleaning: 手順 10、 2の画像 2
    • Remove the scroll wheel cover and replace plastic wheel (or cover if that appears to be the issue.) Clean both with Q-tip or soft fabric.
終わりに
作成者
4人の作成者と共同で作成されました。
Melanie
メンバー登録日: 09/11/23
187 ポイント
1ガイドが承認済み
チーム
University of Colorado Denver, Team 1-4, Campeau Fall 2023 University of Colorado Denver, Team 1-4, Campeau Fall 2023人のメンバー
UCDENVER-CAMPEAU-F23S1G4
7 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 32
過去 30 日: 105
今までの合計 850
