はじめに
It happens that the shaft of a magic wand no longer turns easily or not at all because some debris has gotten into ist. It may help to put the shaft in hot water, but you will probably have to clean and re-grease it. If the motor turns but the shaft does not, the rubber coupling may be broken. This guide shows how to repair these failures. Bamix is proud that even very old wands can be repaired. Spare parts are available, for example in europe from Unold or Bamix.
必要な工具と部品
この手順で使用する道具:iFixit Precision 4 mm Screwdriver Bit$2.99
Remove two Torx TR10 screws.
Carefully lift off the cover. It is latched at the front.
First try If the bell can be unscrewed. It is fastened with a left-hand thread, so turn it in the "wrong direction", clockwise, to loosen it.
Pull on the knife to remove it
If it does not come off easily, then slide the lower plastic part towards the bell and clamp the motor in a vice. Do not tighten the vice very much, the motor is sensitive.
Use a long screwdriver as a lever between the bell and the shaft. Then carefully unscrew the bell. Reminder: the wrong way round, i.e. clockwise.
Pay attention to the washer between the shaft and the bell, do not lose it.
Using a Torx T15 screwdriver unscrew the two screws securing the flange of the shaft to the motor.
Seperate the flange including the shaft from the motor.
Carefully push out the shaft. You may need to use a hammer.
Make shure, that you do not lose the two washers.
There is a curved metal washer between bell and shaft...
...and a flat plastic washer between rubber coupling and shaft.
If the surface of the shaft is no longer smooth, e.g. due to corrosion, use very fine sandpaper.
Thoroughly clean the inside of the sleeve and the shaft itself, e.g. with cleaning powder for the dishwasher and a pipe cleaner. Lubricate them thinly with food-grade grease before reassembly.
12 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
VauWehさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
26 件のコメント
Meine Welle wird immer heiß. Auseinander hatte ich den Mixer schon, aber die Info, wie man die Welle ausbaut fehlte mir. Jetzt werde ich es vermutlich morgen nochmal versuchen. Heute ist schon spät. Bin schon gespannt, wie die Welle aussieht. Anstatt 40 EUR für neuen Abtrieb. Also, ich werde berichten. Danke liebe(r) Autor/in)
Vielen herzlichen Dank! Der Zauberstab funktioniert nun wieder. Den Stift, der das Messer hält, habe ich bei mir allerdings auch mit großem Kraft- und Zangenaufwand nicht entfernt bekommen.
Kann mir jemand sagen ob bei ihm Essensreste oder so etwas zu finden waren? Ich habe im SWR gesehen, dass die Keimbelastung in Pürierstäben extrem ist. Leider war kein ESGE zu sehen. Mein Stab funktioniert einwandfrei, trotzdem mache ich mir Gedanken ob ich die Welle reinigen müsste, möchte aber nicht da rum fummeln, wenn es gar nicht nötig ist.
Es wäre schön wenn mir jemand antworten würde.
