メインコンテンツにスキップ
EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement
必要な工具と部品
  1. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the machine is unplugged.
    • Turn the power switch counterclockwise into the OFF position.
  2. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the screw from the red knob: 手順 2、 1の画像 1
    • Use a Phillips screwdriver to remove the screw from the center of the red on/off knob.
  3. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the knob: 手順 3、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the knob: 手順 3、 2の画像 2
    • Remove the red knob.
    • This component is keyed. During reassembly, ensure it is reinstalled in the correct orientation.
  4. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the black cap: 手順 4、 1の画像 1
    • Remove the black plastic cap from the center of the switch assembly.
  5. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 5、 1の画像 1
    • Use a Phillips screwdriver to remove the two screws securing the yellow switch guide to the switch assembly.
    • During reassembly, ensure this component is installed in the same orientation, with the circle in the 6 o'clock OFF position.
  6. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 6、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 6、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 6、 3の画像 3
    • Remove the yellow switch guide from the switch assembly.
    • Remove the black plastic spacer from underneath the yellow switch guide.
  7. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the upper switch housing: 手順 7、 1の画像 1
    • Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
    • These screws may not come out of their recesses in the housing once they are completely unthreaded. If some stay inside once loose, don't lose track of them.
  8. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 8、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 8、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 8、 3の画像 3
    • Lift the upper half of the switch housing off of the lower half."
    • The rubber gasket may fall out of the upper housing during the removal process. Do not forget to reinstall the gasket upon reassembly.
  9. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Disconnect the power cord from the frame: 手順 9、 1の画像 1
    • Use a 3/8 inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
  10. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the loom clamp: 手順 10、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the loom clamp: 手順 10、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the loom clamp: 手順 10、 3の画像 3
    • Remove the loom clamp from the power cable.
  11. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the switch housing: 手順 11、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the switch housing: 手順 11、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the switch housing: 手順 11、 3の画像 3
    • Use a socket to remove the four 11/32 inch nuts from the on/off switch bracket.
    • During reassembly, use a Phillips screwdriver in combination with the 11/32 inch socket wrench to tighten the bolts securing the switch to the bracket."
  12. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 12、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 12、 2の画像 2
    • Lift the switch assembly off of the switch bracket.
    • The switch housing bolts may fall out when you remove the housing.
  13. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Disconnect the green wires: 手順 13、 1の画像 1
    • Use a flathead screwdriver to remove the screw securing the two green ground wires to the switch housing.
  14. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 14、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 14、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 14、 3の画像 3
    • Separate the green ground wires from each other and move them away from the switch housing.
  15. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Disconnect the power cord from the switch: 手順 15、 1の画像 1
    • Use a flathead screwdriver to loosen the two screws on the right side of the switch assembly securing the black and white wires from the power cord.
    • During reassembly, ensure each wire is installed in its correct location on the switch.
  16. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 16、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 16、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 16、 3の画像 3
    • Remove the black wire from the switch.
  17. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 17、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 17、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 17、 3の画像 3
    • Remove the white wire from the switch.
  18. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 18、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 18、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 18、 3の画像 3
    • Use a 1-1/16 inch wrench or an adjustable wrench to loosen the power cord's strain relief fitting from the switch housing.
    • Once the fitting is loose enough to turn by hand, twist the power cord and fitting counterclockwise until it is fully unthreaded from the switch housing.
  19. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the power cord: 手順 19、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the power cord: 手順 19、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Remove the power cord: 手順 19、 3の画像 3
    • Remove the power cord from the on/off switch.
  20. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Transfer the strain relief fitting to the new cord: 手順 20、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement, Transfer the strain relief fitting to the new cord: 手順 20、 2の画像 2
    • If the replacement power cord comes with a strain relief fitting pre-installed, skip the remaining steps and begin reassembly
    • Use two adjustable wrenches to unscrew the strain relief fitting by turning the locknut counterclockwise relative to the fitting.
    • 1-1/16 inch lock nut
    • 15/16 inch strain relief fitting
    • Reassembly tip: note the length from the end of the power cord to the strain relief fitting. Match this length as close as possible when reinstalling the fitting.
  21. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 21、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 21、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 21、 3の画像 3
    • Remove the lock nut from the power cord.
  22. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 22、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 22、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 22、 3の画像 3
    • Insert a flathead screwdriver into the fitting and push the blue grommet out to remove it from the housing.
  23. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 23、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 23、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 23、 3の画像 3
    • Remove the fitting from the power cord.
  24. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 24、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 24、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 24、 3の画像 3
    • Remove the grommet from the power cord.
  25. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 25、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 25、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 25、 3の画像 3
    • Remove the remaining nut and washer from the power cable.
    • These may have slid down the power cable during the previous steps.
  26. EDCO Floor Stripper TS8 .75L (2017) Power Cord Replacement: 手順 26、 1の画像 1
    • Only the power cord remains.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Robert Boyd
メンバー登録日: 02/01/21
29,860 ポイント
94のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 18
今までの合計 652
