メインコンテンツにスキップ
EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement
必要な工具と部品
  1. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the machine is unplugged.
    • Turn the power switch counterclockwise into the OFF position.
  2. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the hood bolts: 手順 2、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the hood bolts: 手順 2、 2の画像 2
    • Use a 1/2 inch socket to remove the four bolts securing the hood to the frame, two on each side.
    • During reassembly, ensure each bolt is reinstalled with both its flat washer and lock washer.
  3. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the hood: 手順 3、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the hood: 手順 3、 2の画像 2
    • Pull the hood away from the device to remove it.
  4. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Loosen the motor mount bolts: 手順 4、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Loosen the motor mount bolts: 手順 4、 2の画像 2
    • Use a 9/16 inch socket to loosen, but not remove, the four bolts securing the motor mount to the frame, two on each side.
  5. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Slide motor mount forward: 手順 5、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Slide motor mount forward: 手順 5、 2の画像 2
    • Slide the motor towards the front of the device to release tension in the belt."
    • Reassembly tip: Tilt the device onto its handles to use the weight of the motor to tension the belt, then tighten down the bolts.
  6. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the belt: 手順 6、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the belt: 手順 6、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the belt: 手順 6、 3の画像 3
    • Remove the belt from the cam shaft pulley.
  7. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 手順 7、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 手順 7、 2の画像 2
    • Disengage the belt from the motor pulley.
    • Remove the belt.
  8. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Tilt the device: 手順 8、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Tilt the device: 手順 8、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Tilt the device: 手順 8、 3の画像 3
    • Tilt the device back to rest on its handle.
    • Ensure that the four 9/16 inch motor mount bolts are tightened before tilting the device.
  9. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Chock the wheels: 手順 9、 1の画像 1
    • Insert wheel chocks behind the wheels to ensure the device does not move or fall during the repair."
  10. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the blade retainer: 手順 10、 1の画像 1
    • Use a 3/16 inch hex key to remove the three bolts securing the blade retainer.
  11. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 手順 11、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 手順 11、 2の画像 2
    • Remove the blade retainer.
  12. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Loosen set screws: 手順 12、 1の画像 1
    • Use a 1/8 inch hex key to loosen the two set screws on the lower flange bearing.
  13. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 手順 13、 1の画像 1
    • Use a 1/8 inch hex key to loosen the two set screws on the middle flange bearing.
    • These set screws require either a long hex key or an extension to reach. They can be accessed from the front of the floor stripper or from the slots on either side of the frame.
  14. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 手順 14、 1の画像 1
    • Use a 9/16 inch socket to remove the two nuts securing the upper flange bearing to the frame.
    • If you are unable to fit a socket on the nuts due to the cam shaft pulley, try using a wrench.
    • If the bolts spin without loosening, use a 9/16 inch wrench to hold the bolt head from underneath.
  15. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the cam shaft assembly: 手順 15、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the cam shaft assembly: 手順 15、 2の画像 2
    • Use a mallet and an appropriately-sized brass punch to tap out the cam shaft assembly if you cannot remove it by hand.
    • Once loose, the cam shaft assembly can fall out quickly.
  16. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 手順 16、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 手順 16、 2の画像 2
    • Remove the cam shaft assembly
終わりに
作成者
1人の作成者と共同作成されました。
Robert Boyd
メンバー登録日: 02/01/21
24,228 ポイント
94のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 321
