メインコンテンツにスキップ
EDCO Floor Stripper TS8 .75L (2017) Belt Replacement
必要な工具と部品
  1. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the machine is unplugged.
    • Turn the power switch counterclockwise into the OFF position.
  2. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood bolts: 手順 2、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood bolts: 手順 2、 2の画像 2
    • Use a 1/2 inch socket to remove the four bolts securing the hood to the frame, two on each side.
    • During reassembly, ensure each bolt is reinstalled with both its flat washer and lock washer.
  3. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood: 手順 3、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood: 手順 3、 2の画像 2
    • Pull the hood away from the device to remove it.
  4. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Loosen the motor mount bolts: 手順 4、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Loosen the motor mount bolts: 手順 4、 2の画像 2
    • Use a 9/16 inch socket to loosen, but not remove, the four bolts securing the motor mount to the frame, two on each side.
  5. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Slide motor mount forward: 手順 5、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Slide motor mount forward: 手順 5、 2の画像 2
    • Slide the motor towards the front of the device to release tension in the belt."
    • Reassembly tip: Tilt the device onto its handles to use the weight of the motor to tension the belt, then tighten down the bolts.
  6. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the belt: 手順 6、 3の画像 1 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the belt: 手順 6、 3の画像 2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the belt: 手順 6、 3の画像 3
    • Remove the belt from the cam shaft pulley.
  7. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement: 手順 7、 2の画像 1 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement: 手順 7、 2の画像 2
    • Disengage the belt from the motor pulley.
    • Remove the belt.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Robert Boyd
メンバー登録日: 02/01/21
24,228 ポイント
94のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 13
今までの合計 325
