必要な工具と部品
Tool board mount is mounted to the Turbiner, before mounting the EBB tool board to the EBB36 PCB Mount.
M3x8 SHCS
Clear Nylon washer
EBB36 PCB
M3 spacer
EBB PCB mount
Molex Microfit 3.0 2x2 connector.
Brown wire-Ground
Green wire-Vcc
White wire CAN H
Yellow wire CAN L
Make sure the sensor cable is plugged into LDO Runout Sensor
Plug runout cable from the runout sensor into the port on the EBB PCB.
4 pin endstop cable
5v
Ground
The Signal Wire will be yellow OR white varies and is not important.
Loosen both screw terminals fully, then insert one wire at a time, fully tightening while holding the wire in place.
Connect Thermistor connector to TH0 port.
