メインコンテンツにスキップ
Dyson v6 Absolute Cyclone Replacement
必要な工具と部品
  1. Dyson v6 Absolute Cyclone Replacement, Bin: 手順 1、 1の画像 1
    • Unplug the device.
  2. Dyson v6 Absolute Cyclone Replacement: 手順 2、 1の画像 1
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Dyson v6 Absolute Cyclone Replacement: 手順 3、 1の画像 1
    • Push the red lever down a second time to release the debris bin.
  4. Dyson v6 Absolute Cyclone Replacement: 手順 4、 1の画像 1
    • Pull bin away from the cyclone.
  5. Dyson v6 Absolute Cyclone Replacement, Main Body: 手順 5、 1の画像 1
    • Separate the bin from the main body of the device.
  6. Dyson v6 Absolute Cyclone Replacement: 手順 6、 1の画像 1
    • Locate two visible white clips between the main body and the cyclone.
  7. Dyson v6 Absolute Cyclone Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    • Use tweezers to pinch the white clips together.
    • Widely hold the tweezers apart to get them to reach between the two white clips.
    • Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
  8. Dyson v6 Absolute Cyclone Replacement: 手順 8、 2の画像 1 Dyson v6 Absolute Cyclone Replacement: 手順 8、 2の画像 2
    • Tilt and pull the main body away from the cyclone.
    • There may be a loud snap when the main body separates from the cyclone.
  9. Dyson v6 Absolute Cyclone Replacement, Cyclone: 手順 9、 1の画像 1
    • Use the spudger to remove the cyclone.
    • Start at the small opening beneath the place where the cyclone connects to the main body.
    • Work the spudger around the rim of the red screen filter.
    • You will hear popping noises.
  10. Dyson v6 Absolute Cyclone Replacement: 手順 10、 2の画像 1 Dyson v6 Absolute Cyclone Replacement: 手順 10、 2の画像 2
    • Use a T9 Torx screwdriver to remove five 14mm screws from the edge of the screen filter body.
  11. Dyson v6 Absolute Cyclone Replacement: 手順 11、 1の画像 1
    • Remove the filter screen cover away from the cyclone.
    • Pull down on the black tube inside the cyclone body to remove it from the cyclone.
終わりに
17 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Tabitha Espina Velasco
メンバー登録日: 01/23/17
3,702 ポイント
5のガイドは作成済み
チーム
Washington State, Team 1-2, Staggers Spring 2017 Washington State, Team 1-2, Staggers Spring 2017人のメンバー
WSU-STAGGERS-S17S1G2
2 メンバー
23のガイドは作成済み
3件のガイドコメント
Very helpful presentation. Reassembly was fiddley as the new cyclone was not broken and needed a very firm waggle and push to engage with the motor body. The white clip is not easy to grasp at the same time as the body and the cyclone.
I found three small broken black plastic pieces under the white clip- from the lugs of the old cyclone - that had to be removed, with tweezers, before assembling the body and cyclone.
John Griggs - 返信
Das Zyklon läßt sich noch viel weiter zerlegen!
Tom - 返信
Schmutz/Staub an den Plastikteilen nach Zerlegung lassen sich gut im Eimer mit Seifenwasser auflösen.
Wieder zusammenbauen erst nach kompletten Trocknen !
Macht mal Fotos von verdrecktem Zyklon.
RepairUli - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 47
過去 30 日: 178
今までの合計 24,119
