メインコンテンツにスキップ
Dyson V8 Absolute Battery Replacement
必要な工具と部品
  1. Dyson V8 Absolute Battery Replacement, Battery: 手順 1、 2の画像 1 Dyson V8 Absolute Battery Replacement, Battery: 手順 1、 2の画像 2
    • Detach wand from device.
    • Use a Phillips #2 screwdriver to unscrew the screw from the device handle.
    • Screw Head Type: Phillips #2
    • Screw Length: 170mm
  2. Dyson V8 Absolute Battery Replacement: 手順 2、 3の画像 1 Dyson V8 Absolute Battery Replacement: 手順 2、 3の画像 2 Dyson V8 Absolute Battery Replacement: 手順 2、 3の画像 3
    • Turn device completely over to view battery pack.
    • Below the bin, use a Phillips #2 screwdriver to remove both screws from the battery back.
  3. Dyson V8 Absolute Battery Replacement: 手順 3、 3の画像 1 Dyson V8 Absolute Battery Replacement: 手順 3、 3の画像 2 Dyson V8 Absolute Battery Replacement: 手順 3、 3の画像 3
    • Pull the battery pack down and away from the device.
    • Battery pack may fall out.
終わりに
51 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jasvir Dosanjh
メンバー登録日: 10/25/17
1,680 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S1-G5, Rose Fall 2017 UW Tacoma, Team S1-G5, Rose Fall 2017人のメンバー
UWT-ROSE-F17S1G5
4 メンバー
15のガイドは作成済み
13 件のコメント
Great instructions!!
akcosta60 - 返信
I have replaced the battery and I still got a flashing red light, any ideas
georgewaterson - 返信
I replaced my battery and charged the new one- my vac doesnt work
grooveon.g - 返信
if you have got the switch on max slide other way plug it to charge for 3,4 minuite then try should work. do not put on max as it will not work and you will have to do it all over again
anthony richards - 返信
My v8 animal has a new battery but it doesn't seem to want to charge. The 1st of the 3 battery lights lights up constantly, the 2nd just flashes and the 3rd never lights up no matter how long it's left on charge. The motor will run ok on the lower setting but cut's out almost instantly in the highest setting.
Could the charger be at fault?
Trunker Trubshaw -
コメントを追加
統計データ:
過去 24時間: 58
過去 7 日: 503
過去 30 日: 2,201
今までの合計 163,793
