はじめに
Connection tube and brushbar will need to be removed before replacement. Housing for the brushbar may be damaged and break overtime.
必要な工具と部品
Turn the padlock key counterclockwise using the iFixit Opening Tool.
7 の人々がこのガイドを完成させました。
6 件のコメント
Took mine apart and i was certain it was the motor. Removed the drive belt and the motor turned freely. Discovered that the brush pulley was stiff and jammed. Freed it up with wd40 and worked the pulley until it loosened right up. Placed the belt back and now works perfectly. Maybe try this before presuming the motor is burnt out? Just a thought. Cheers!
