メインコンテンツにスキップ
Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement
必要な工具と部品
  1. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement, Brush Bar: 手順 1、 1の画像 1
    • Press the button to disconnect the vacuum head from the connecting pole.
  2. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 2、 1の画像 1
    • Turn the end cap counterclockwise using the iFixit Opening Tool.
    • If you do not have an iFixit Opening Tool, a quarter may be used instead.
  3. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 3、 3の画像 1 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 3、 3の画像 2 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 3、 3の画像 3
    • Pull the brush bar out of the housing.
  4. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement, Upper Housing and Brush Bar Housing: 手順 4、 2の画像 1 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement, Upper Housing and Brush Bar Housing: 手順 4、 2の画像 2
    • Turn the padlock key counterclockwise using the iFixit Opening Tool.
  5. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 5、 1の画像 1
    • Unscrew the three front 1.4 cm torx screws using the T8 Torx screwdriver.
  6. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 6、 2の画像 1 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 6、 2の画像 2
    • Remove the upper plate once the padlock is unlocked.
  7. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 7、 3の画像 1 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 7、 3の画像 2 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 7、 3の画像 3
    • Unscrew the top two corner 1.4 cm torx screws using the iFixit T8 Torx screwdriver.
    • Remove axie and roller after the screws are taken out.
  8. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 8、 1の画像 1
    • Remove the drive assembly from vacuum housing.
    • Red wire connecting the drive assembly to housing.
  9. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 9、 3の画像 1 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 9、 3の画像 2 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: 手順 9、 3の画像 3
    • Pop off the circular plating to remove the housing from the connection piece.
    • Red wire connects through the upper portion of the housing.
終わりに
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Addie Hedge
メンバー登録日: 01/24/17
710 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 22-6, Maness Winter 2017 Cal Poly, Team 22-6, Maness Winter 2017人のメンバー
CPSU-MANESS-W17S22G6
4 メンバー
5のガイドは作成済み
6 件のコメント
can the direct drive motor unit be replaced rather than replacing the whole motor head. If so where can the motor be purchased from - I’ve internet searched without success!
Mikey - 返信
I am in the same boat, any luck finding just the direct drive motor ?
jerryd -
You can try ebay.
Joe - 返信
Took mine apart and i was certain it was the motor. Removed the drive belt and the motor turned freely. Discovered that the brush pulley was stiff and jammed. Freed it up with wd40 and worked the pulley until it loosened right up. Placed the belt back and now works perfectly. Maybe try this before presuming the motor is burnt out? Just a thought. Cheers!
Paul Stewart - 返信
I’ve disassembled and see the black wire is broken! Has anyone done this?
lawrence - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 28
今までの合計 14,253
