メインコンテンツにスキップ
Dyson V6 Motorhead Brush Bar Replacement
必要な工具と部品
  1. Dyson V6 Motorhead Brush Bar Replacement, Brush Bar: 手順 1、 1の画像 1
    • Press the button to disconnect the vacuum head from the connecting pole.
  2. Dyson V6 Motorhead Brush Bar Replacement: 手順 2、 1の画像 1
    • Turn the end cap counterclockwise using the iFixit Opening Tool.
    • If you do not have an iFixit Opening Tool, a quarter may be used instead.
  3. Dyson V6 Motorhead Brush Bar Replacement: 手順 3、 3の画像 1 Dyson V6 Motorhead Brush Bar Replacement: 手順 3、 3の画像 2 Dyson V6 Motorhead Brush Bar Replacement: 手順 3、 3の画像 3
    • Pull the brush bar out of the housing.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Addie Hedge
メンバー登録日: 01/24/17
710 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 22-6, Maness Winter 2017 Cal Poly, Team 22-6, Maness Winter 2017人のメンバー
CPSU-MANESS-W17S22G6
4 メンバー
5のガイドは作成済み
4 件のコメント
Not so fast, there are teeth on the lower roll insert that can interfere with teeth on the housing. Is there a purpose for these teeth, maybe manufacturing mold release? My brush roll will not turn when re-installed. It installs easily, powers up, spins about 4 or 5 revolutions, then shuts off power for a second, then comes back on without the roller spinning at all. I can see it is the teeth interlocking but don’t know how it makes the first 4 or 5 revs. Very strange indeed!!
dooleyew - 返信
I have the same problem, where the teeth seem to be engaging and stopping the revolutions. Any fix for this?
Dave Duddleston - 返信
I have the same problem and I never signed up for the warranty.
Donna Sweeney - 返信
My motorhead works intermittely. I took it apart and cleaned everything to no avail. The guy at Starks vacuum in Sherwood OR said it was plugged and he would take it apart and clean it for $100. Hmmmm, what can he clean that I can’t?
Roger and Karen Risch - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 40
今までの合計 21,919
