はじめに
If your remote doesn’t work the first thing you should check is the battery; being a very simple device it's very likely that the battery has died. For the replacement all you are going to need is Phillips #1 Screwdriver and a new CR2032L coin cell battery. The battery should last you upwards of 10 years with normal use so don't expect to be back in this guide anytime soon.
必要な工具と部品
Use a Phillips #1 screwdriver to loosen the screw at the base of the remote.
もう少しです!
終わりに
