はじめに
If, after consulting the troubleshooting page, you believe your oscillation motor has blown, this guide will walk you through accessing it to do your own repair/replacement. The oscillation motor is wired directly into the devices main circuitry and thus requires knowledge and experience to replace. This guide will simply cover how to access and remove it.
必要な工具と部品
Using a T20 Torx screwdriver, remove the two screws on either side of the motor.
もう少しです!
ゴール
ある他の人がこのガイドを完成しました。
