メインコンテンツにスキップ
Dyson DC58 Main Body Replacement
必要な工具と部品
ビデオの概要
  1. Dyson DC58 Main Body Replacement, Bin: 手順 1、 1の画像 1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Main Body Replacement: 手順 2、 1の画像 1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Main Body Replacement: 手順 3、 1の画像 1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Main Body Replacement: 手順 4、 2の画像 1 Dyson DC58 Main Body Replacement: 手順 4、 2の画像 2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Main Body Replacement, Main Body: 手順 5、 1の画像 1
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Main Body Replacement: 手順 6、 2の画像 1 Dyson DC58 Main Body Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Main Body Replacement: 手順 7、 1の画像 1
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
終わりに
12 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Krista St Onge
メンバー登録日: 09/17/15
2,212 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team 2-4, Bruce Fall 2015 CSU Fullerton, Team 2-4, Bruce Fall 2015人のメンバー
CSUF-BRUCE-F15S2G4
4 メンバー
19のガイドは作成済み
4件のガイドコメント
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - 返信
Has anyone replaced the red release catch?
chrisashton1 - 返信
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - 返信
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 17
過去 30 日: 57
今までの合計 14,008
