メインコンテンツにスキップ
Dyson DC58 Cyclone Replacement
必要な工具と部品
  1. Dyson DC58 Cyclone Replacement, Bin: 手順 1、 1の画像 1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Cyclone Replacement: 手順 2、 1の画像 1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Cyclone Replacement: 手順 3、 1の画像 1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Cyclone Replacement: 手順 4、 2の画像 1 Dyson DC58 Cyclone Replacement: 手順 4、 2の画像 2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Cyclone Replacement, Main Body: 手順 5、 1の画像 1
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Cyclone Replacement: 手順 6、 2の画像 1 Dyson DC58 Cyclone Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Cyclone Replacement: 手順 7、 1の画像 1
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
  8. Dyson DC58 Cyclone Replacement, Cyclone: 手順 8、 2の画像 1 Dyson DC58 Cyclone Replacement, Cyclone: 手順 8、 2の画像 2
    • Use the metal spudger placed between the black rim and the purple rim to separate the purple screen cover from the cyclone body.
    • Pry all the way around the screen cover.
  9. Dyson DC58 Cyclone Replacement: 手順 9、 1の画像 1
    • Use a T9 screw driver to remove the five 14mm screws around the edge of the cyclone body.
  10. Dyson DC58 Cyclone Replacement: 手順 10、 2の画像 1 Dyson DC58 Cyclone Replacement: 手順 10、 2の画像 2
    • Pull down on the black tube-like part of the silver cyclone body to remove it from the cyclone of the Dyson.
    • You may need to wiggle the tube as you are pulling down to loosen the pieces apart.
終わりに
22 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Herllaine Asistio
メンバー登録日: 09/17/15
239 ポイント
1ガイドが承認済み
チーム
CSU Fullerton, Team 2-4, Bruce Fall 2015 CSU Fullerton, Team 2-4, Bruce Fall 2015人のメンバー
CSUF-BRUCE-F15S2G4
4 メンバー
19のガイドは作成済み
11件のガイドコメント
Great job, very useful thanks
Don - 返信
Fantastic thanks!!!!
robh - 返信
Very helpful indeed.
macx - 返信
Thanks. Had to wash out the dog smell. This did the trick.
David Parsons - 返信
Thanks. Had to wash out the dog smell. This did the trick when new filters wouldn't. Shame on Dyson for not making an easier to clean vacuum.
David Parsons - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 52
過去 30 日: 378
今までの合計 27,379
