この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください。
はじめに
バッテリーは、掃除機を手で持てるようにし、持ち運べるようにするためにあります。バッテリーによって、約3.5時間使用し続けることができます。
必要な工具と部品
#1プラスドライバーで10mmプラスネジを外します。
You also have to remove the screw at the top on the back where the motor is. Otherwise, the battery will not come out!
Mayme Kittman.
Isn't that what the next step of the instructions tells you to do?
Ray Bellamy.
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
9 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
83%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
9 件のコメント
Works for the DC44 animal also. :)
Vu Nguyen and contributors should definitely go back in and REVISE these instructions to include the second screw mentioned by Mike 7/29/18. I almost broke my vacuum because I trust iFixit to vet their content. I discovered the second screw after going to another site and only saw Mike’s post after returning here to see if I missed something - I did: I didn’t read his comments!
Yikes! Thanks goodness I read the comments before I too almost broke something by not removing the second screw!
Mike, thank you. cliff is right, revise this please
louturks23 - 返信
How do you test the battery to see if it should be replaced? Why does it have two round prongs and two flat prongs? It will run for 5 seconds sometimes and 5 minutes sometimes not able to tell why.
the upper screw on the handle on the dc56 type b seems to have a glassy lock-tite substance on mine. it has to be scraped away to expose the screw.
Nice process description with great photos: much thanks, as I could NOT find the second shorter screw…..FOR the life of me. THANKS
