メインコンテンツにスキップ
Dyson DC24 Dust Bin O-Ring Replacement
必要な工具と部品
  1. Dyson DC24 Dust Bin O-Ring Replacement, Dust Bin O-Ring: 手順 1、 3の画像 1 Dyson DC24 Dust Bin O-Ring Replacement, Dust Bin O-Ring: 手順 1、 3の画像 2 Dyson DC24 Dust Bin O-Ring Replacement, Dust Bin O-Ring: 手順 1、 3の画像 3
    • Remove the dirt container by clicking on the red button.
    • Pull away the container from the main body.
  2. Dyson DC24 Dust Bin O-Ring Replacement: 手順 2、 2の画像 1 Dyson DC24 Dust Bin O-Ring Replacement: 手順 2、 2の画像 2
    • Push on the gray release tab on the back of the container.
    • This separates the clear container piece from the filter/suction region.
  3. Dyson DC24 Dust Bin O-Ring Replacement: 手順 3、 3の画像 1 Dyson DC24 Dust Bin O-Ring Replacement: 手順 3、 3の画像 2 Dyson DC24 Dust Bin O-Ring Replacement: 手順 3、 3の画像 3
    • Grab the top filter piece and pull the clear tab out towards you and this should release the top chamber and reveal a filter.
  4. Dyson DC24 Dust Bin O-Ring Replacement: 手順 4、 1の画像 1
    • Remove the filter from the dust container.
    • Depending on the level of cleanliness of the filter you will need to clean it or order a new one.
  5. Dyson DC24 Dust Bin O-Ring Replacement: 手順 5、 2の画像 1 Dyson DC24 Dust Bin O-Ring Replacement: 手順 5、 2の画像 2
    • Use a T15 screwdriver to carefully unscrew and remove five 19.1 mm screws.
    • Make sure to keep the red plastic piece. When putting the pieces back together you will need to orient the red plastic piece properly (see arrow for piece).
  6. Dyson DC24 Dust Bin O-Ring Replacement: 手順 6、 3の画像 1 Dyson DC24 Dust Bin O-Ring Replacement: 手順 6、 3の画像 2 Dyson DC24 Dust Bin O-Ring Replacement: 手順 6、 3の画像 3
    • On the bottom of the piece that lifts up, you will see a hexagonal divider ring. This can be removed by lifting from an edge and pulling.
  7. Dyson DC24 Dust Bin O-Ring Replacement: 手順 7、 3の画像 1 Dyson DC24 Dust Bin O-Ring Replacement: 手順 7、 3の画像 2 Dyson DC24 Dust Bin O-Ring Replacement: 手順 7、 3の画像 3
    • On the bottom piece, there is a second more traditional-looking o-ring. Remove this by grabbing the ring, pulling it out towards you, and down.
終わりに
With the completion of step 7, you are done. To reassemble your device, follow these instructions in reverse order.
作成者
2人の作成者と共同で作成されました。
Angel Verdejo
メンバー登録日: 01/26/23
145 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 1-4, Morris Winter 2023 UC Davis, Team 1-4, Morris Winter 2023人のメンバー
UCD-MORRIS-W23S1G4
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 15
今までの合計 196
