メインコンテンツにスキップ
Dyson DC19 Allergy Vacuum Cleaner disassembly
必要な工具と部品
  1. Dyson DC19 Allergy Vacuum Cleaner disassembly, Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 1、 2の画像 1 Dyson DC19 Allergy Vacuum Cleaner disassembly, Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 1、 2の画像 2
    • Detatch the cyclone assembly from the main unit.
  2. Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 2、 2の画像 1 Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 2、 2の画像 2
    • Take the waste bin and cyclone assembly apart.
  3. Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 3、 3の画像 1 Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 3、 3の画像 2 Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 3、 3の画像 3
    • Pull the bottom cone out of the assembly.
    • When re-assembling: there are three slots on the outer edge of the assembly that the cone matches. This is shown in picture 2. You might have to press the cone down with your thumb as in picture 3. When re-assembling, remember to fit the rubber gasket on the cone before inserting the cone in the body.
  4. Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 4、 2の画像 1 Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 4、 2の画像 2
    • Remove the gasket surrounding the bottom cone.
  5. Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 5、 1の画像 1
    • Remove the seven torx screws which hold the top cover in place (one is located in the middle of the handle). You need a torx T15 driver for this.
  6. Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 6、 1の画像 1
    • Remove the seven torx screws which hold the cyclone manifold in place. You need a torx T15 driver for this.
  7. Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 7、 2の画像 1 Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 7、 2の画像 2
    • Remove the manifold and the gasket underneath it.
  8. Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 8、 3の画像 1 Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 8、 3の画像 2 Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 8、 3の画像 3
    • Flip the assembly over and remove the three plastic tabs covering the screws, then remove the screws. When re-assembling note that the screw holes align only in one way.
    • A good way to remove the tabs is to insert a small flat-head driver between the the tab and turn. (In the place marked in picture.)
  9. Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 9、 3の画像 1 Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 9、 3の画像 2 Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 9、 3の画像 3
    • Take the the cyclone assembly apart by pulling the two pieces away from each other. Note that these parts may be stuck together so you might have to use some amount of force. You can now remove the gasket between the parts.
    • When re-assembling note that you have to press the two pieces together really hard until you hear/feel a click.
  10. Dyson DC19 Allergy Vacuum Cleaner disassembly: 手順 10、 1の画像 1
    • Everything is washable, do not use too hot water.
終わりに
17 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Sami
メンバー登録日: 07/04/11
628 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 52
今までの合計 23,644
