メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dyson DC14 Motor Replacement
必要な工具と部品
  1. Dyson DC14 Motor Replacement, Brush Bar: 手順 1、 1の画像 1
    • Turn off the vacuum and unplug it from the outlet.
    • Lay the vacuum on its top so that the brush bar faces you.
    FixBotに聞いてみる
    コメントを追加
  2. Dyson DC14 Motor Replacement: 手順 2、 3の画像 1 Dyson DC14 Motor Replacement: 手順 2、 3の画像 2 Dyson DC14 Motor Replacement: 手順 2、 3の画像 3
    • Using a quarter, turn the three soleplate fasteners 90 degrees to the left.
    • Holding the soleplate on both sides, tilt it down and away from the vacuum.
    • Remove the soleplate from the vacuum.
    FixBotに聞いてみる
    コメントを追加
  3. Dyson DC14 Motor Replacement: 手順 3、 2の画像 1 Dyson DC14 Motor Replacement: 手順 3、 2の画像 2
    • Turn down the squared tabs on the brushbar so that they face outward.
    • Use a screwdriver to pry the belt up from the brushbar.
    • Be careful not to cut the belt with the screwdriver.
    • While holding the belt, pull the brushbar to the left and remove it from the vacuum.
    • You can let go of the belt when it's free from the brushbar. The belt will not retract into the vacuum.
    • During reassembly, insert the brushbar with the tabs facing outward, then rotate the tabs up to lock the brushbar in place.
    FixBotに聞いてみる
    コメントを追加
  4. Dyson DC14 Motor Replacement, Motor: 手順 4、 2の画像 1 Dyson DC14 Motor Replacement, Motor: 手順 4、 2の画像 2
    • Place vacuum upright, with the canister facing you.
    • Remove the canister, setting the canister aside.
    FixBotに聞いてみる
    コメントを追加
  5. Dyson DC14 Motor Replacement: 手順 5、 3の画像 1 Dyson DC14 Motor Replacement: 手順 5、 3の画像 2 Dyson DC14 Motor Replacement: 手順 5、 3の画像 3
    • Insert flathead screwdriver under each latch and pry up gently.
    • Do not try to lift the latches up very far, they could snap off!
    • Open the cover, remove the exhaust filter, and set the filter to the side
    FixBotに聞いてみる
    コメントを追加
  6. Dyson DC14 Motor Replacement: 手順 6、 2の画像 1 Dyson DC14 Motor Replacement: 手順 6、 2の画像 2
    • Place vacuum face down.
    • Remove the u-bend pipe that connects the canister to the telescopic wand.
    FixBotに聞いてみる
    コメントを追加
  7. Dyson DC14 Motor Replacement: 手順 7、 2の画像 1 Dyson DC14 Motor Replacement: 手順 7、 2の画像 2
    • Pull the clear hose out of the gasket on the right side of the vacuum under the axle.
    • Pull the hose straight back towards you.
    FixBotに聞いてみる
    コメントを追加
  8. Dyson DC14 Motor Replacement: 手順 8、 2の画像 1 Dyson DC14 Motor Replacement: 手順 8、 2の画像 2
    • Remove brush-bar housing by prying the housing out of the clips that hold it.
    • Pull brush-bar housing toward you while keeping vacuum stationary.
    FixBotに聞いてみる
    コメントを追加
  9. Dyson DC14 Motor Replacement: 手順 9、 1の画像 1
    • Remove the three T15 torx screws that secure the cover to the brush clutch belt.
    FixBotに聞いてみる
    コメントを追加
  10. Dyson DC14 Motor Replacement: 手順 10、 2の画像 1 Dyson DC14 Motor Replacement: 手順 10、 2の画像 2
    • Pull the cover of the brush clutch belt out towards you.
    • Pull belt to the right to remove the belt from the brush clutch axle.
    • To reassemble your vacuum, pull the belt with your finger towards the axle. (Using a screwdriver, or a similar device, will delay access to the axle.)
    FixBotに聞いてみる
    コメントを追加
  11. Dyson DC14 Motor Replacement: 手順 11、 2の画像 1 Dyson DC14 Motor Replacement: 手順 11、 2の画像 2
    • Insert a flat-head screwdriver into the two locking rings to remove the rings, which are located above the wheels on both sides.
    • These rings secure the bottom assembly of the vacuum to the rest of the unit.
    FixBotに聞いてみる
    コメントを追加
  12. Dyson DC14 Motor Replacement: 手順 12、 2の画像 1 Dyson DC14 Motor Replacement: 手順 12、 2の画像 2
    • Remove the four T15 torx screws that secure the motor housing to the vacuum.
    • Remove the elbow-bend pipe on the right-side of the vacuum.
    • Press the two release latches on either side of the elbow-bend pipe. Pull it out and away from the vacuum.
    FixBotに聞いてみる
    コメントを追加
  13. Dyson DC14 Motor Replacement: 手順 13、 1の画像 1
    • Place the vacuum right-side up and leave it standing up.
    • Remove the right side cover by pushing the release latch down while lifting the cover towards you.
    FixBotに聞いてみる
    コメントを追加
  14. Dyson DC14 Motor Replacement: 手順 14、 2の画像 1 Dyson DC14 Motor Replacement: 手順 14、 2の画像 2
    • Set vacuum the on its back.
    • Pull away the plastic cover of the motor housing.
    • A bit of force may be needed.
    FixBotに聞いてみる
    コメントを追加
  15. Dyson DC14 Motor Replacement: 手順 15、 1の画像 1
    • Insert flat head screwdriver between gray motor housing and black motor.
    • Pry motor cover housing away.
    FixBotに聞いてみる
    コメントを追加
  16. Dyson DC14 Motor Replacement: 手順 16、 2の画像 1 Dyson DC14 Motor Replacement: 手順 16、 2の画像 2
    • Release the motor assembly from its housing by strongly hitting the brush clutch axle with a hammer.
    • The rubber grommets covering the motor may be greasy.
    FixBotに聞いてみる
    コメントを追加
  17. Dyson DC14 Motor Replacement: 手順 17、 1の画像 1
    • Remove motor from housing slowly.
    • Do not pull the motor completely out of the housing. The motor is connected to the vacuum by two wires.
    FixBotに聞いてみる
    コメントを追加
  18. Dyson DC14 Motor Replacement: 手順 18、 2の画像 1 Dyson DC14 Motor Replacement: 手順 18、 2の画像 2
    • Remove the power terminals from both sides of the motor.
    • Do not pull by the wires when removing terminal. This can result in damage to your vacuum.
    • These terminals will only fit one way (i.e. only one end is long enough to reach to the far side of the motor).
    • Remove the motor from the housing completely.
    FixBotに聞いてみる
    コメントを追加
  19. Dyson DC14 Motor Replacement: 手順 19、 1の画像 1
    • Remove the two rubber grommets from your old motor, then transfer them to your new motor.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
23 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Miriam Krage
メンバー登録日: 10/07/12
267 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 3-22, Amido Fall 2012 Cal Poly, Team 3-22, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S3G22
4 メンバー
8のガイドは作成済み
12件のガイドコメント
Rather than use a screwdriver for belt removal & risk injury or machine damage, why not use the proper belt tool ?. It saves time & possible injury and is available for not much more than the cost of a decent quality flat head screwdriver.
Andy - 返信 共有
Motor works beater bar does not turn
carlalewis - 返信 共有
What if its not the motor
carlalewis - 返信 共有
Great guide! A useful tip for getting the motor (or specifically the rubber cover) into the motor case: smear some washing up liquid or liquid soap around the inside of the motor case, and the rubber will slip in a lot easier. Keep an eye nf the rotational position of the motor (so that it fits the hole at the axle end correctly), and make sure you don't trap the 2 power wires.
Paul Blitz - 返信 共有
Great tutorial, replacement motor cost £12, Dyson now back up and working. Only issue I had was that when replacing the motor housing in the Hoover, make sure it fits into the bottom groove or else the screw hole on the brush clutch cover won't line up. You'll know it's not in the groove if you're having trouble with the screw. Just go back and under the four screws, lift out the motor housing and seat it in again, that'll sort it out.
Blue - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 88
今までの合計 55,877
