メインコンテンツにスキップ
Dyson Cinetic Big Ball Animal Upright Filter Replacement
必要な工具と部品
  1. Dyson Cinetic Big Ball Animal Upright Filter Replacement, Filter: 手順 1、 1の画像 1
    • Start on the left side of the Dyson Ball.
  2. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 手順 2、 1の画像 1
    • Remove the center 18mm screw from the Dyson Ball, then remove the covering.
  3. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 手順 3、 1の画像 1
    • Next, remove the upper right 18mm screw along the perimeter of the circle.
  4. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 手順 4、 1の画像 1
    • Continuing clockwise along the path, remove the next 18mm screw.
  5. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 手順 5、 1の画像 1
    • Remove the next 18mm screw at the lower edge of the circle.
  6. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 手順 6、 1の画像 1
    • Then remove the final 18mm screw in the center. Once these have all been unscrewed, remove the filter with the cover. The filter and the cover should be attached to each other.
  7. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 手順 7、 1の画像 1
    • Gently unclip the cover from the filter.
  8. Dyson Cinetic Big Ball Animal Upright Filter Replacement: 手順 8、 1の画像 1
    • This is how it should look once the covering has been removed.
終わりに
To reassemble your device, follow these instructions in reverse order. The Dyson has two filters, so if the problem has not been resolved, you may have to repeat this process on the other side.
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Karla Sunjara
メンバー登録日: 01/24/17
891 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S13-G1, Banghart Winter 2017 Cal Poly, Team S13-G1, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S13G1
3 メンバー
10のガイドは作成済み
4 件のコメント
Can this filter be washed?
mariabrooke0828 - 返信
No it's not a washable filter and is supposed to last the life of the machine - hmm… still going to get clogged with fine dust though so yif contact Dyson! They don't last and the increased clogging can reduce the life of the motor.
Scott -
Can you buy a replacement filter?? Thank you.
Lori Turner - 返信
I’ve bought a second hand dyson big ball cleaner. It’s stinks of dogs. How can I take it apart and clean it?
Joyce haras - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 44
過去 30 日: 190
今までの合計 31,529
