はじめに
Unable to quickly remove your canister from the vacuum body? This guide will show you how to replace the spring inside the opening mechanism.
必要な工具と部品
If the top handle does not pop up when trying to remove canister, press the gray button as you gently pull up on the top handle.
もう少しです!
終わりに
