メインコンテンツにスキップ
Dyson Ball Multi Floor Upright Electrical Cord Replacement
必要な工具と部品
  1. Dyson Ball Multi Floor Upright Electrical Cord Replacement, Electrical Cord: 手順 1、 2の画像 1 Dyson Ball Multi Floor Upright Electrical Cord Replacement, Electrical Cord: 手順 1、 2の画像 2
    • Press the red button on the back to release the hose and allow for easy access to the back
  2. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 手順 2、 1の画像 1
    • Remove the four 15 mm T-10 black screws now showing in the back of the vacuum hose track, using the Phillips 0 screwdriver found in the iFixit tool kit.
  3. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 手順 3、 2の画像 1 Dyson Ball Multi Floor Upright Electrical Cord Replacement: 手順 3、 2の画像 2
    • Use a pair of needle nosed pliers to press both tabs simultaneously.
    • Hold onto the front hatch while doing this or it will fall off and a spring and lever will fall out with it.
    • Remove the hatch carefully exposing the wiring underneath
  4. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 手順 4、 2の画像 1 Dyson Ball Multi Floor Upright Electrical Cord Replacement: 手順 4、 2の画像 2
    • Remove the black wire from its connection near the top of the hatch
  5. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 手順 5、 2の画像 1 Dyson Ball Multi Floor Upright Electrical Cord Replacement: 手順 5、 2の画像 2
    • Open the black box near the bottom of the hatch area using the two push tabs
    • This exposes the white wire's connection
  6. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 手順 6、 1の画像 1
    • Disconnect the white wire using the small metal tab.
    • Do not damage the wire during the process.
  7. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 手順 7、 1の画像 1
    • Pull vertically on the grey cord now and it should separate from the rest of the vacuum
    • To replace the cord, slide the new grey cord into place and connect the two wires again then complete the steps in reverse
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Nicole Abraham
メンバー登録日: 01/26/17
839 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 21-2, Maness Winter 2017 Cal Poly, Team 21-2, Maness Winter 2017人のメンバー
CPSU-MANESS-W17S21G2
4 メンバー
10のガイドは作成済み
コメント 1 件
Supposing that one doesn't hold onto the front part, and the spring and lever fall out, how does one replace said spring and lever?
Jordan Adams - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 45
今までの合計 3,746
