はじめに
Diese Anleitung zeigt dir, wie du den Schlauch bei Verstopfung, gebrochener Dichtung oder anderen Fehlfunktionen entfernen kannst.
必要な工具と部品
Schalte das Gerät aus und ziehe den Netzstecker, drehe dann das Gerät, so dass du auf den Schlauch schaust.
Um dein Gerät wieder zusammenzubauen, folge den Schritten dieser Anleitung in umgekehrter Reihenfolge.
13 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
9 件のコメント
I used the hose and attachments on my ball animal + up13 and after removal of attachment and stowing the hose to the handle assy. , I can not get the vacumm to stop sucking from the top of the handle? I’ve attempted reading the owners manual (which is not user friendly) and also watched Youtube demonstrations with no luck. This has been two days of struggling with no success???
The suction is diverted to the hose when the machine is upright. Stand behind the machine, pull the handle towards you and the transfer valve automatically diverts the suction to the brush head. Put it back into the upright position and suction automatically diverts to the rear hose.
mike.vardy - 返信
can anyone show me a picture of the transfer valve? I think it is not going into position when I try to use the wand.
it looks like the wand has a round plastic device in middle is this correct? i have taken the wand out of the hose and the hose has suction but when all goes back together and turn on the hand held wand device has no suction
