メインコンテンツにスキップ
ビデオの概要
この分解は修理ガイドでは ありません。 お持ちのDyson AM10 Humidifierを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Dyson AM10 Humidifier Tear-Down, Clean, Repair, Clean the tank, lots of brush positioning: 手順 1、 3の画像 1 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Clean the tank, lots of brush positioning: 手順 1、 3の画像 2 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Clean the tank, lots of brush positioning: 手順 1、 3の画像 3
    • Use these brushes from AliExpress to clean the tank insides. Each one provides a slightly different position. Together they cost about $7 and can be used for other hard-to-reach places. The tank has a few unreachable places which are in the last 2 images. I cleaned >95% of the moss.
  2. Dyson AM10 Humidifier Tear-Down, Clean, Repair, Open the fan, wash it out: 手順 2、 3の画像 1 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Open the fan, wash it out: 手順 2、 3の画像 2 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Open the fan, wash it out: 手順 2、 3の画像 3
    • Need torx (star-shaped) screwdriver (8 & 10). BE CAREFUL with screws, because they are anchored in the plastic!! Too far and you crack it, so use your hands and move slowly. A few tools to get: Magnetizer to hold torx screws, Lastly, image 1 shows me sliding the top forward into the tabs - move slowly because it feels fragile.
  3. Dyson AM10 Humidifier Tear-Down, Clean, Repair, Fan apart View: 手順 3、 3の画像 1 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Fan apart View: 手順 3、 3の画像 2 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Fan apart View: 手順 3、 3の画像 3
    • I rinsed it with water There are 3 levels of screws to take out: The white outside cover, this black capsule in frame #2 and the rotor in my hand (image #3).
  4. Dyson AM10 Humidifier Tear-Down, Clean, Repair, The head: 手順 4、 3の画像 1 Dyson AM10 Humidifier Tear-Down, Clean, Repair, The head: 手順 4、 3の画像 2 Dyson AM10 Humidifier Tear-Down, Clean, Repair, The head: 手順 4、 3の画像 3
    • In image 1 I'm pressing the white outside with my thumb while digging fingernails in this crack and pulling up carefully. Work your way around slowly and the rim comes off. I have no idea how to get the rest apart and I don't think you need it.
  5. Dyson AM10 Humidifier Tear-Down, Clean, Repair, The Atomizer: 手順 5、 2の画像 1 Dyson AM10 Humidifier Tear-Down, Clean, Repair, The Atomizer: 手順 5、 2の画像 2
    • The atomizer or nebulizer is the core feature which creates the mist. In the main photo, it is clearly electrified and ultrasonically vibrates and breaks up (nebulizes) the water into the mist. The 'charged' disc underside has 3 'rings': the shiny anode and cathode (positive and negative) separated by a non-conducting dark ceramic ring.
  6. Dyson AM10 Humidifier Tear-Down, Clean, Repair, Replacing the Piezo Atomizer: 手順 6、 1の画像 1
    • Ideally, someone will contribute a link to a vender for these atomizer discs which truly cost about $0.25 each. Sadly, on Amazon there are $47 repair kits. I would be willing to buy 100 for $25, contact me. This top of this TDK disc has damage from normal use. Note the shiny conductive top layer over the ceramic showing through from underneath.
作成者
2人の作成者と共同で作成されました。
Paul Tast
メンバー登録日: 09/17/16
984 ポイント
7のガイドは作成済み
2件のガイドコメント
Nowadays it seems difficult to find the brushes. Do you have a tag or link towards those? Maybe even on another platform?
Oliver Hinz - 返信
I bought these and other things on AliExpress.
Paul Tast - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 42
過去 30 日: 166
今までの合計 5,124
