メインコンテンツにスキップ
Dysan DC14 Duct Replacement
必要な工具と部品
    • Avoid frightening the house cats.
    • Remove dust receptacle (Cyclone Assembly) and any attachments and set aside.
    • Remove the u-bend pipe, intake cover, exhaust cover and set aside.
    • Remove the hose assembly by releasing it from the bottom by depressing a latch via a hole through the lower half of the duct while pulling it upward.
    • Remove the screw(s) from the power switch cover plate, found on the opposite site of the duct from the power switch. The cover plate swings away from the duct at the top, then lifts up and off. Set it and the power button aside.
    • Pull the motor power cord out of the channel.
    • Disconnect the white wire at the connector below the power switch.
    • Pull the power switch and the wall cord that should still be attached by its black wire out of the old duct.
    • Install the power cord and switch into the new duct.
    • Pull both the black and white motor wires out of the opening they go through at the top of the duct. Note the location of this opening.
    • Pull the motor wires out of the channel they are embedded into all the way to the bottom.
    • Remove the oval black rubber gasket (exhaust seal) at the top of the duct and install it on the new duct. Notice that there is a notch in the gasket that must be aligned for proper installation.
    • Slightly below the exhaust seal is another rectangular rubber gasket (entry seal). Transfer it to the new duct, noting it too has a notch that needs to be aligned properly.
    • You do not need to transfer the bottom most seal (exhaust pre-filter seal) over to the new duct. The part that it is installed on will be transferred to the new duct and will move with it. This step is coming up soon
    • Remove the crevice tool clip and install it onto the new duct.
    • Squeeze the sides of the canister latch and pull it out. Do not lose the spring behind it. Reinstall the latch and spring onto the new duct.
    • Pry off the hubcap.
    • Remove the metal e-clip from the shaft. This clip will attempt to fly across the room and vanish from this dimension. Do not let it.
    • Pull the small metal washer and the wheel from the shaft.
    • Slide the remaining wheel and shaft out and reinstall it and the other wheel back onto the new duct.
    • The pivot points for the Cleaner Head assembly have two plastic Bearing Clips, the ends of which are embedded into a recess on their shafts. Pry the ends out the recess and work the clips off of the shafts.
    • Remove the large plastic washers (Cleaner Head Pivot Circlips) underneath the clips.
    • Pull out the Motor Inlet Cover Catch. It pulls straight out and may put up a fight.
    • Turn the unit over.
    • Remove the sole plate by rotating the three large slotted screws a quarter turn and lifting the plate off, pivoting toward the front.
    • Yank the flexible hose off of the Port Plate.
    • Remove the right rear screw holding the exhaust pipe assembly.
    • Remove the exhaust pipe assembly. This is tricky. It kinda pulls up and to the right
    • Remove the port plate. One end unsnaps then pivots out on the other end. Remember that you are disposing of the piece this is coming out of while trying to save this piece, so act accordingly.
    • Remove the forward lock and spring by depressing the sides inward to disengage the pivots and then pulling out.
    • Remove the valve carriage.
    • Reinstall the valve carriage onto the new duct.
    • Reinstall the port plate, by pivoting the widest end first, then snapping the smaller end into place.
    • Reinstall the forward lock and spring into the new duct.
    • Remove the five remaining screws from the bottom of the unit.
    • Lift the Cleaner Head assembly pivot points over the tops of the shafts.
    • The old duct should now be able to come off and be disposed of. Make sure nothing removable remains on it before disposing.
    • After removing the old duct from the motor, fit the new one to it.
    • Replace the five screws removed earlier.
    • Reinstall the exhaust pipe assembly and screw it down.
    • Reinstall the Motor Inlet Cover Catch. Press it firmly in until it is seated.
    • Slide the Cleaner Head pivot points back over their pivots.
    • Reinstall the plastic washers (Cleaner Head Pivot Circlips) over the pivots.
    • Reinstall the Bearing Clips onto the pivots and seat the ends back into the recesses for them.
    • Reinstall the Hose Assembly into the base of the duct.
    • Reconnect the flexible hose for the beater bar to the port plate.
    • Reinstall the sole plate that was removed in step 18.
    • Starting at the bottom and working upward, press the motor power cord into its channel or groove in the new duct.
    • At the top, pass the motor power cord connectors through the same hole you noted earlier, next to the switch.
    • Reconnect the white wire from the motor to the white wire from the power cord.
    • Reconnect the black wire from the motor to the terminal on the switch.
    • Push the switch back into its slot with the plunger facing up.
    • Place the button on top of the switch
    • Reinstall the switch cover plate by first engaging its tabs at the bottom into the new duct, then pivoting it into place. Replace the screw(s) that go in from other side of the new duct.
    • Reinstall the u-bend pipe, intake cover, and exhaust cover.
    • Reinstall the dust receptacle (Cyclone Assembly).
終わりに
You should be done.
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Prof. Mayhem
メンバー登録日: 01/21/18
523 ポイント
1ガイドが承認済み
2 件のコメント
Many pictures needed ie. one or two for each step.
Marybeth Weber - 返信
Pictures would definitely be helpful but guide was very useful regardless!
mtbm33 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 17
今までの合計 1,262
