メインコンテンツにスキップ
Dynex DX-WBRDVD1 Power Supply Board Replacement
必要な工具と部品
  1. Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: 手順 1、 2の画像 1 Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: 手順 1、 2の画像 2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Power Supply Board Replacement: 手順 2、 1の画像 1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Power Supply Board Replacement: 手順 3、 1の画像 1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: 手順 4、 2の画像 1 Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: 手順 4、 2の画像 2
    • Remove the 9-pin white wire from the power board (brown) that connects to the motherboard (green).
  5. Dynex DX-WBRDVD1 Power Supply Board Replacement: 手順 5、 2の画像 1 Dynex DX-WBRDVD1 Power Supply Board Replacement: 手順 5、 2の画像 2
    • Remove the front plate of the device by removing the top two screws on either side and pulling the plate away.
    • Make sure to place the grounding wire between the screw and the device when reassembling.
  6. Dynex DX-WBRDVD1 Power Supply Board Replacement: 手順 6、 2の画像 1 Dynex DX-WBRDVD1 Power Supply Board Replacement: 手順 6、 2の画像 2
    • Remove the 4 screws holding the power board to the body of the device.
    • Remember to connect a grounding wire to the screw next to the front panel and optical drive when reassembling.
  7. Dynex DX-WBRDVD1 Power Supply Board Replacement: 手順 7、 2の画像 1 Dynex DX-WBRDVD1 Power Supply Board Replacement: 手順 7、 2の画像 2
    • Press down on the plastic flap to unlatch the white clip on the edge of the power supply board.
  8. Dynex DX-WBRDVD1 Power Supply Board Replacement: 手順 8、 1の画像 1
    • Remove the power supply board.
終わりに
3 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Caleigh Firth
メンバー登録日: 04/05/18
438 ポイント
3のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 689
