はじめに
The discdrive is found next to the motherboard and power board inside the device. This guide will take you through the steps of removing the discdrive for replacement.
必要な工具と部品
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
2 の人々がこのガイドを完成させました。
