メインコンテンツにスキップ
Dynex DX-WBRDVD1 Motherboard Replacement
必要な工具と部品
  1. Dynex DX-WBRDVD1 Motherboard Replacement, Top Cover: 手順 1、 2の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement, Top Cover: 手順 1、 2の画像 2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 3、 1の画像 1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Motherboard Replacement, WiFi Antenna: 手順 4、 3の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement, WiFi Antenna: 手順 4、 3の画像 2 Dynex DX-WBRDVD1 Motherboard Replacement, WiFi Antenna: 手順 4、 3の画像 3
    • Use the metal spudger to remove the white clip from the antenna by prying the clip away from the antenna.
    • Use a pointed tool and press down on the indents on both sides of the clip to loosen.
  5. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the two 7mm screws from both sides of the antenna.
  6. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 6、 2の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 6、 2の画像 2
    • Slide the antenna inwards and gently remove.
  7. Dynex DX-WBRDVD1 Motherboard Replacement, Motherboard: 手順 7、 1の画像 1
    • After removing the antenna, remove the hdmi screw (5mm)
    • Fine threaded
  8. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 8、 1の画像 1
    • Remove component screw (7mm)
    • Corse thread
  9. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 9、 1の画像 1
    • Lift power cord and move to the side
  10. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 10、 2の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 10、 2の画像 2
    • Remove the white clip with colored wires from mother board.
    • Use a pointed tool and press in on the sides of the clip to release.
  11. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 11、 3の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 11、 3の画像 2 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 11、 3の画像 3
    • Lift up and out to remove the large white plastic wiring strip. Lift lightly on the back clip holding it to loosen.
  12. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 12、 2の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 12、 2の画像 2
    • Remove the power connection to the motherboard small white clip with 4 white wires coming out.
    • Press sides and pull up the edges with sharp tool
  13. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 13、 2の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 13、 2の画像 2
    • Pull the 1cm white tab straight up and out.
    • The side with exposed wires points towards the face plate.
  14. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 14、 2の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 14、 2の画像 2
    • Pull the larger white 9 pin power cord that connects the power board to the motherboard.
  15. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 15、 3の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 15、 3の画像 2 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 15、 3の画像 3
    • Pull the second white 1cm wide tab between the motherboard and power supply board.
    • The side with exposed wires points towards the disc drive.
  16. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 16、 2の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 16、 2の画像 2
    • Remove the two 5mm screws that connect the mother board to the device.
  17. Dynex DX-WBRDVD1 Motherboard Replacement: 手順 17、 3の画像 1 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 17、 3の画像 2 Dynex DX-WBRDVD1 Motherboard Replacement: 手順 17、 3の画像 3
    • Slide board up and out at a slight angle
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Harrison Williams
メンバー登録日: 04/05/18
499 ポイント
2のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 270
