メインコンテンツにスキップ
Durofix RV332 Motor Replacement
必要な工具と部品
  1. Durofix RV332 Motor Replacement, Screwdriver Motor: 手順 1、 1の画像 1
    • Remove the six 13 mm case screws with philips #0 screwdriver.
  2. Durofix RV332 Motor Replacement: 手順 2、 2の画像 1 Durofix RV332 Motor Replacement: 手順 2、 2の画像 2
    • Use the plastic separating tool to separate the casing halves of the cordless screwdriver.
  3. Durofix RV332 Motor Replacement: 手順 3、 2の画像 1 Durofix RV332 Motor Replacement: 手順 3、 2の画像 2
    • Once the screwdriver casings have been separated, remove the printed circuit board, battery, LED, and motor assembly from the screwdriver casing.
    • Using the wire cutters, cut the black and red motor wires where they connect to the motor.
  4. Durofix RV332 Motor Replacement: 手順 4、 1の画像 1
    • Strip the ends of the wires clean with the wire cutters. Strip the wire insulation 1/4" from the end of the wire.
  5. Durofix RV332 Motor Replacement: 手順 5、 3の画像 1 Durofix RV332 Motor Replacement: 手順 5、 3の画像 2 Durofix RV332 Motor Replacement: 手順 5、 3の画像 3
    • Ensure the new motor terminals are clean before soldering.
    • Solder the red wire to the positive motor terminal, designated by a plus sign with a red circle around it.
    • Solder the black wire to the other terminal of the motor.
    • Allow the newly soldered assembly to cool before continuing.
  6. Durofix RV332 Motor Replacement: 手順 6、 1の画像 1
    • Once the motor has cooled, replace the motor, printed circuit board, LED, and battery inside the screwdriver casing.
終わりに
作成者
3人の作成者と共同で作成されました。
Tyler Vincent
メンバー登録日: 02/24/14
479 ポイント
4のガイドは作成済み
チーム
Michigan Tech, Team 5-5, Lauer Spring 2014 Michigan Tech, Team 5-5, Lauer Spring 2014人のメンバー
MTU-LAUER-S14S5G5
3 メンバー
5のガイドは作成済み
コメント 1 件
Too late finding this (although self-explanatory). I was wondering when I tried this - WHERE does one find the spare component motor to replace? I searched the internet, but for something so specific, I just couldn't locate the right channels. For future reference, is there a typical store of small motors, etc... to locate these things?
Arkadiusz - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 15
今までの合計 826
