メインコンテンツにスキップ
Ducky One 3 SF Keycaps and Switches Replacement
必要な工具と部品
  1. Ducky One 3 SF Keycaps and Switches Replacement, Keycaps and Switches: 手順 1、 2の画像 1 Ducky One 3 SF Keycaps and Switches Replacement, Keycaps and Switches: 手順 1、 2の画像 2
    • Disconnect the cable from your keyboard.
    • Place the keyboard on a flat and stable surface.
  2. Ducky One 3 SF Keycaps and Switches Replacement: 手順 2、 3の画像 1 Ducky One 3 SF Keycaps and Switches Replacement: 手順 2、 3の画像 2 Ducky One 3 SF Keycaps and Switches Replacement: 手順 2、 3の画像 3
    • Use the switch puller to remove the keycap from the keyboard.
    • Remove all of the keycaps you need to replace or clean.
  3. Ducky One 3 SF Keycaps and Switches Replacement: 手順 3、 2の画像 1 Ducky One 3 SF Keycaps and Switches Replacement: 手順 3、 2の画像 2
    • Place the keycaps in a container.
  4. Ducky One 3 SF Keycaps and Switches Replacement: 手順 4、 3の画像 1 Ducky One 3 SF Keycaps and Switches Replacement: 手順 4、 3の画像 2 Ducky One 3 SF Keycaps and Switches Replacement: 手順 4、 3の画像 3
    • Use a key switch puller to secure the switch at the top and bottom.
    • Pull the switch away from the keyboard.
    • Ensure the switch puller is positioned and secured between the switch and the keyboard to prevent any damage to the switch.
  5. Ducky One 3 SF Keycaps and Switches Replacement: 手順 5、 1の画像 1
    • Place all of the switches from the keyboard in a container.
  6. Ducky One 3 SF Keycaps and Switches Replacement: 手順 6、 1の画像 1
    • Use a dust blower to remove loose debris from your keyboard.
    • Use a foam tipped swab and Isopropyl Alcohol to clean any residue, oils, or grime from the keyboard.
    • Make sure the keyboard is completely dry before replacing the switches and keycaps.
  7. Ducky One 3 SF Keycaps and Switches Replacement: 手順 7、 1の画像 1
    • Soak the keycaps in soapy water.
    • Remove all dirt or debris from each keycap.
  8. Ducky One 3 SF Keycaps and Switches Replacement: 手順 8、 1の画像 1
    • Let the keycaps sit for 10-20 minutes to disinfect.
    • Rinse the keycaps with water.
    • Place them on a towel and use a cloth to remove excess water.
    • Leave the keycaps to air dry.
    • Ensure that the keycaps are completely dry before proceeding to the next step.
  9. Ducky One 3 SF Keycaps and Switches Replacement: 手順 9、 3の画像 1 Ducky One 3 SF Keycaps and Switches Replacement: 手順 9、 3の画像 2 Ducky One 3 SF Keycaps and Switches Replacement: 手順 9、 3の画像 3
    • Insert the new switch into the corresponding holes in the keyboard and push the switch into position.
    • Make sure that the switch pins line up correctly with the holes on the keyboard so they don't get bent or damaged.
    • Continue the process until all switches are in place.
  10. Ducky One 3 SF Keycaps and Switches Replacement: 手順 10、 3の画像 1 Ducky One 3 SF Keycaps and Switches Replacement: 手順 10、 3の画像 2 Ducky One 3 SF Keycaps and Switches Replacement: 手順 10、 3の画像 3
    • Replace each keycap in the correct position and press onto the key switch.
    • Use the following website to confirm both the correct positioning and functionality of the keycap.
終わりに
Hopefully these steps were clear and useful to you!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Tony Lee
メンバー登録日: 01/10/24
181 ポイント
1ガイドが承認済み
チーム
York University, Team 2-18, O'Regan Winter 2024 York University, Team 2-18, O'Regan Winter 2024人のメンバー
YORK-O'REGAN-W24S2G18
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 33
今までの合計 113
