メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
DualShock 4 Ribbon Cable Replacement
必要な工具と部品
  1. DualShock 4 Ribbon Cable Replacement, Check your controller model: 手順 1、 1の画像 1
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
  2. DualShock 4 Ribbon Cable Replacement, Unfasten the rear case: 手順 2、 2の画像 1 DualShock 4 Ribbon Cable Replacement, Unfasten the rear case: 手順 2、 2の画像 2
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
  3. DualShock 4 Ribbon Cable Replacement, Remove the L1 button: 手順 3、 3の画像 1 DualShock 4 Ribbon Cable Replacement, Remove the L1 button: 手順 3、 3の画像 2 DualShock 4 Ribbon Cable Replacement, Remove the L1 button: 手順 3、 3の画像 3
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
  4. DualShock 4 Ribbon Cable Replacement, Remove the R1 button: 手順 4、 1の画像 1
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
  5. DualShock 4 Ribbon Cable Replacement, Unclip the rear case: 手順 5、 3の画像 1 DualShock 4 Ribbon Cable Replacement, Unclip the rear case: 手順 5、 3の画像 2 DualShock 4 Ribbon Cable Replacement, Unclip the rear case: 手順 5、 3の画像 3
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
  6. DualShock 4 Ribbon Cable Replacement: 手順 6、 3の画像 1 DualShock 4 Ribbon Cable Replacement: 手順 6、 3の画像 2 DualShock 4 Ribbon Cable Replacement: 手順 6、 3の画像 3
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
  7. DualShock 4 Ribbon Cable Replacement: 手順 7、 1の画像 1
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
  8. DualShock 4 Ribbon Cable Replacement: 手順 8、 3の画像 1 DualShock 4 Ribbon Cable Replacement: 手順 8、 3の画像 2 DualShock 4 Ribbon Cable Replacement: 手順 8、 3の画像 3
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
  9. DualShock 4 Ribbon Cable Replacement, Remove the rear case: 手順 9、 3の画像 1 DualShock 4 Ribbon Cable Replacement, Remove the rear case: 手順 9、 3の画像 2 DualShock 4 Ribbon Cable Replacement, Remove the rear case: 手順 9、 3の画像 3
    • Press the R2 button and slide the rear case over it.
  10. DualShock 4 Ribbon Cable Replacement: 手順 10、 1の画像 1
    • Press the L2 button and slide the rear case over it.
  11. DualShock 4 Ribbon Cable Replacement: 手順 11、 3の画像 1 DualShock 4 Ribbon Cable Replacement: 手順 11、 3の画像 2 DualShock 4 Ribbon Cable Replacement: 手順 11、 3の画像 3
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
  12. DualShock 4 Ribbon Cable Replacement, Disconnect the interconnect cable: 手順 12、 3の画像 1 DualShock 4 Ribbon Cable Replacement, Disconnect the interconnect cable: 手順 12、 3の画像 2 DualShock 4 Ribbon Cable Replacement, Disconnect the interconnect cable: 手順 12、 3の画像 3
    この手順で使用する道具:
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
  13. DualShock 4 Ribbon Cable Replacement, Unfasten the light guide bracket: 手順 13、 1の画像 1
    • Use your Phillips screwdriver to remove the two 6.4 mm screws securing the light guide bracket to the rear case.
  14. DualShock 4 Ribbon Cable Replacement, Remove the light bar bracket: 手順 14、 3の画像 1 DualShock 4 Ribbon Cable Replacement, Remove the light bar bracket: 手順 14、 3の画像 2 DualShock 4 Ribbon Cable Replacement, Remove the light bar bracket: 手順 14、 3の画像 3
    • Remove the black spacer and white bracket from the light guide.
  15. DualShock 4 Ribbon Cable Replacement, Peel the foam pads: 手順 15、 3の画像 1 DualShock 4 Ribbon Cable Replacement, Peel the foam pads: 手順 15、 3の画像 2 DualShock 4 Ribbon Cable Replacement, Peel the foam pads: 手順 15、 3の画像 3
    • Peel both foam pads from the light guide.
  16. DualShock 4 Ribbon Cable Replacement, Remove the light guide: 手順 16、 3の画像 1 DualShock 4 Ribbon Cable Replacement, Remove the light guide: 手順 16、 3の画像 2 DualShock 4 Ribbon Cable Replacement, Remove the light guide: 手順 16、 3の画像 3
    • Grab and lift the light guide from its alignment pegs on the rear case.
    • Remove the light guide.
  17. DualShock 4 Ribbon Cable Replacement, Remove the light diffuser: 手順 17、 3の画像 1 DualShock 4 Ribbon Cable Replacement, Remove the light diffuser: 手順 17、 3の画像 2 DualShock 4 Ribbon Cable Replacement, Remove the light diffuser: 手順 17、 3の画像 3
    • Push the light diffuser through the inside of the rear case and remove it.
  18. DualShock 4 Ribbon Cable Replacement, Ribbon Cable: 手順 18、 2の画像 1 DualShock 4 Ribbon Cable Replacement, Ribbon Cable: 手順 18、 2の画像 2
    この手順で使用する道具:
    • Use your thumb to hold down the clear plastic cover to create space to remove the ribbon cable.
    • With the cover held down, use tweezers to remove the faulty ribbon cable.
終わりに
9 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Mohamed Ahmed
メンバー登録日: 01/27/21
436 ポイント
2のガイドは作成済み
チーム
York University, Team S16-G1, Turner Winter 2021 York University, Team S16-G1, Turner Winter 2021人のメンバー
YORK-TURNER-W21S16G1
3 メンバー
3のガイドは作成済み
1件のガイドコメント
One other thing I would recommend is before you install the new ribbon cable, I installed a layer of Polyamide/Kapton Tape on both sides of the cable before installing and flexing/bending - this in theory reduces the severity of the bends, which I'd say is what causes the wires to break internally. It doesn't have to necessarily be Kapton tape, just any tape to provide some structural support against crushing/creasing would help :)
Aadi Bhamidipati - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 107
過去 30 日: 518
今までの合計 24,390
