はじめに
Over time, your DualShock 4 controller will probably be dropped, stepped on, or even thrown. The plastic shell helps to protect the internal components of the controller, but eventually, you might find that this protective shell needs to be replaced or re-aligned. This step-by-step process will show you how to fix this problem yourself.
To remove the plastic shell, use the Phillips #00 screwdriver to remove the four 6.0 mm screws securing the back of the controller.
30 の人々がこのガイドを完成させました。
5 件のコメント
can you go over the removal of the shell in detail? this barely teaches anything at all
i have done this before. once you separate the controller, there will be a flat white cable connecting the bottom to the top. that is the charging port, so disconnect that. after, remove the battery and the black plastic piece. there will be a screw either holding the black piece on, or a hole on the black piece where a screw is. this screw is holding the motherboard to the top shell. take that screw out. then on the top right of the motherboard, unplug that wire. that is the touchpad cable. then, you should be able to take the motherboard out. then, there will be rubber pieces holding all of the top buttons in. on the d pad and action buttons, there are 4 little spots where they attach. on the power button, there are 2 spots. hope this helps
Nice job, you taught us how to take the screws off the controller. Congratulations!!!
Shut up smart
Wow. This is useless
