必要な工具と部品
ピンセットを使ってリボンケーブルをマザーボードポートから引き抜き、両側を完全に分離します。
If you just want to change the battery, this step is not necessary; it can be done without disconnecting the ribbon cable.
マザーボード上にある電源ポートから黒と赤のワイヤの接続を外します。
コントローラーから古いバッテリーを取り出します。
Be extra careful - the power port socket pulled loose from the motherboard for me. I would suggest holding down the socket itself with one tool and gradually loosening the plug from the port.
プラスネジ ドライバーを使って、マザーボードをコントローラーの内部構造に接続している6.43mmネジを外します
this and the last step arnt necessary you just put the battery back and connect all of it up
Joe Flores - 返信
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
41 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
2 件のコメント
Where can I buy cuh zct2e spares from please
When re-asembling, be careful to check that all buttons/triggers are moving correctly. They can get misaligned when prying the two shell halves apart.
Tale Spinner - 返信
This part is missing vital information on how to correctly pry the case open. In the 3rd picture you can see there is actually damaged/broken clip already. In order to open the case without damage to the plastic clips inside the controller holding the plastics together you need to insert thin piece of metal between the trigger buttons on each side and push the clip outwards before trying to separate the parts, and if done correctly there is no force needed to pry open the controller. There is actually no necessary need for the clips, but if you want to keep your controller in mint condition without voiding the warranty, take care not to break these clips.
Ville Närhi - 返信
Your advice for opening shell was so bad and harmful.
It's not correct
Kiarash Moallemi - 返信
And two more tiny clips to the left and right of the headphone & EXT port. They’re VERY delicate, reckless prying WILL break at least ONE of these.
Strings Cat - 返信
I've written a guide for how to find and unlatch the clips
DualShock 4 CUH-ZCT2Uを開くための重要な作業
Richard - 返信
