必要な工具と部品
USBモジュールを固定している2本のネジを緩めます。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
prednin5mgさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
6 件のコメント
Thanks this was so helpful because every time I do this I break it like literally break the plastic
Do you know where I can get broken PS4 controllers?
it doesn’t come out like that. upon opening the chassis, everything is stuck to the top part of the controller, not the bottom part.
This video on how to open a ps4 controller should help you too : https://youtu.be/9Chgw4sRTzs
you need to open up the 2 tabs near the USB port to removed the top cover after removing the 4 screws in the back.
Clarence Kong - 返信
This is nowhere near enough information. Removing the four screws gets nothing off, and no idea what “2 tabs” the above comment is talking about. The controller would stay together completely with or without the screws…
Manjushri - 返信
right away this guide give you nothing in terms of actual information on actually taking apart the duel shock 4
Eden - 返信
