メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
    • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
  2. Slide the trigger button retainers slightly away from the front cover. Remove the #1 button on both sides. Remove the #1 button on both sides.
    • Slide the trigger button retainers slightly away from the front cover.
    • Remove the #1 button on both sides.
  3. Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly. Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
    • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
  4. Remove the motherboard assembly from the front cover.
    • Remove the motherboard assembly from the front cover.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
終わりに
Andrew Bookholt
569,662 ポイント
618のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,537
