はじめに
This is a teardown of a dual USB port bracket with LED activity lights for a desktop computer. These brackets, which mount on any open expansion card slot on a computer chassis, add two USB ports to the back of a computer using a connection to a 9-pin USB header on a motherboard. This one came out of a desktop with an MSI motherboard.
必要な工具と部品
This part of the bracket consists of the circuit board enclosed in a plastic housing, which we will tear down in the next step.
These connectors plug into the USB headers on the motherboard.
この手順で使用する道具:Phillips #1 Screwdriver$5.49
Use a Phillips #1 screwdriver to remove the four screws from the white casing and the two screws from the metal bracket.
The two USB 2.0 ports.
The four LED lights, which light up depending on the activity of the USB ports.
