はじめに
This guide helps you dissasembling the Dual BT 10 Bluetooth Speaker to get to the mainboard for further troubleshooting and repairs.
In my case, I needed to repair the ON/OFF switch and found some difficulties while dissasembling the device without damaging it. This guide therefore should help you with the disassembly.
Tools needed:
- Philipps head screw driver
- Thin blade (cutter knife / exacto knife / etc.)
Turn the device upside down
Remove the two foam feet at the front end of the speaker (the end with the buttons)
Unscrew the two screws revealed by the foam pads
Turn the device in its normal position (standing on the foam feet)
Remove the screw cover using a thin blade at the front end of the device (the end with the buttons)
Unscrew the screw and remove it together with its plastic seating
Gently pull the rubber strap to remove it from the silver front housing
Pull the silver front housing from the main body of the device
Disconnect all cables:
Disconnect the battery first (fat red/black cable, red socket)
Disconnect the two front speakers (blue/white cables)
Disconnect the Subwoofer and LED cable (brown/black, red/black cables)
Remove the red antenna wire by loosening it from the marked plastic taps
Remove the four screws holding the front mesh
Separate the black plastic from the silver part
Disconnect the brown cable from the small PCB to fully remove the black plastic
Pull out the main board from the assembly
Carefully feed the antenna wire through its small hole if needed
To reassemble the device, follow all steps in reverse order
When reinserting the motherboard, be careful to place it inside the plastic guides in the black plastic / mesh cover
When pluging in all cables, it is recommended to plug in the battery last (thick red/black cable, red socket)
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
ある他の人がこのガイドを完成しました。
