メインコンテンツにスキップ
Dryer Power Cord Replacement
必要な工具と部品
  1. Dryer Power Cord Replacement, Dryer Power Cord: 手順 1、 3の画像 1 Dryer Power Cord Replacement, Dryer Power Cord: 手順 1、 3の画像 2 Dryer Power Cord Replacement, Dryer Power Cord: 手順 1、 3の画像 3
    • Before starting this guide, TURN OFF THE BREAKER SWITCH related to the dryer.
    • Doing this will help to avoid bodily harm, and also protect the wires from shorting out.
    • Locate your breaker box - (Some are outside and some are inside the house).
    • Once it is found, find the dryer switch and push it to the LEFT to turn it off.
  2. Dryer Power Cord Replacement: 手順 2、 3の画像 1 Dryer Power Cord Replacement: 手順 2、 3の画像 2 Dryer Power Cord Replacement: 手順 2、 3の画像 3
    • Unplug the dryer from the wall.
    • Use a screwdriver to remove any screws that secure the power cord cover.
  3. Dryer Power Cord Replacement: 手順 3、 2の画像 1 Dryer Power Cord Replacement: 手順 3、 2の画像 2
    • Remove the panel by sliding it to the LEFT.
  4. Dryer Power Cord Replacement: 手順 4、 1の画像 1
    • Now that the panel is off, you can see the wires needed to be replaced.
    • The configuration of the wires are power at the top (Usually represented as RED or BLACK)
    • The ground wire is in the middle (Usually represented as WHITE)
    • The bottom wire is also a power wire also (Usually represented as RED or BLACK)
  5. Dryer Power Cord Replacement: 手順 5、 3の画像 1 Dryer Power Cord Replacement: 手順 5、 3の画像 2 Dryer Power Cord Replacement: 手順 5、 3の画像 3
    • Remove the screws that hold the three wires in place.
  6. Dryer Power Cord Replacement: 手順 6、 2の画像 1 Dryer Power Cord Replacement: 手順 6、 2の画像 2
    • You should now be able to remove the power cord freely.
  7. Dryer Power Cord Replacement: 手順 7、 2の画像 1 Dryer Power Cord Replacement: 手順 7、 2の画像 2
    • Now remove the green screw in order to remove the grounding bracket.
  8. Dryer Power Cord Replacement: 手順 8、 3の画像 1 Dryer Power Cord Replacement: 手順 8、 3の画像 2 Dryer Power Cord Replacement: 手順 8、 3の画像 3
    • With everything removed, you can now bring in your new 4 prong power cord.
    • Unlike the old power cord, the new power cord should have the color of what type of wire it is (ex. red for power and white for ground).
    • You can start screwing in the wires with the removed screws from the old cord to the new RED WIRE at the TOP.
    • With the WHITE WIRE, grab the gold plate and put it on top of the wire. Grab the screw and put it on top of the gold plate and screw it in the MIDDLE.
  9. Dryer Power Cord Replacement: 手順 9、 3の画像 1 Dryer Power Cord Replacement: 手順 9、 3の画像 2 Dryer Power Cord Replacement: 手順 9、 3の画像 3
    • Screw the BLACK WIRE at the BOTTOM regularly like the red wire.
    • You should have an extra green wire as this is placed where you saw the green screw in the beginning.
    • Grab the green wire and put it at the end of the gold plate and grab the green screw to screw it in for a tight connection.
  10. Dryer Power Cord Replacement: 手順 10、 3の画像 1 Dryer Power Cord Replacement: 手順 10、 3の画像 2 Dryer Power Cord Replacement: 手順 10、 3の画像 3
    • Slide the panel back over the power cord and screw it back in.
  11. Dryer Power Cord Replacement: 手順 11、 2の画像 1 Dryer Power Cord Replacement: 手順 11、 2の画像 2
    • Plug your dryer back into the socket and go to your breaker box to turn the power back on.
    • You can now use your dryer in your new home.
    • If your dryer does not turn on check your breaker box to make sure it did not short your circuit. If so turn the breaker switch to the OFF position and check wiring connections.
終わりに
To reassemble to the 3 prong configuration, follow these instructions in reverse order.
作成者
3人の作成者と共同で作成されました。
Ronnie Mitchell
メンバー登録日: 09/29/21
193 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team 1-7, Cameron Fall 2022 University of Memphis, Team 1-7, Cameron Fall 2022人のメンバー
UM-CAMERON-F22S1G7
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 49
今までの合計 534
