メインコンテンツにスキップ
Drum Head Replacement
必要な工具と部品
  1. Drum Head Replacement, Drum Head: 手順 1、 1の画像 1
    • Loosen the tension rods until all rods are free from the drum.
    • The tension rods are universal for all drums and drum sets.
  2. Drum Head Replacement: 手順 2、 1の画像 1
    • Remove the rim and drum head.
    • Keep track of the tension rods by leaving them in their holders on the rim.
  3. Drum Head Replacement: 手順 3、 1の画像 1
    • Put on the new drum head first.
    • Put the rim on, making sure that the tension rods are properly aligned.
  4. Drum Head Replacement: 手順 4、 1の画像 1
    • Tighten the tension rods with your fingers until you begin to feel tension.
    • You do not want them completely tightened yet. You just want to make sure the head is not wrinkled.
  5. Drum Head Replacement: 手順 5、 3の画像 1 Drum Head Replacement: 手順 5、 3の画像 2 Drum Head Replacement: 手順 5、 3の画像 3
    • Begin to tighten the tension rods in a star pattern using a drum key.
    • Do not tighten the tension rods in a clockwise or counter clockwise pattern.
    • Tighten the rods until you find the sound you want from the drum.
  6. Drum Head Replacement: 手順 6、 1の画像 1
    • While tightening the tension rods, tap a drumstick on the drum head about an inch from the tension rods.
    • This is how you will determine which tension rods need to be tightened, loosened, or left alone.
  7. Drum Head Replacement: 手順 7、 3の画像 1 Drum Head Replacement: 手順 7、 3の画像 2 Drum Head Replacement: 手順 7、 3の画像 3
    • Once you have found the sound you like and the drum is in tune, push around the middle of the drum head, moving around the drum.
    • Repeat Steps 6 and 7 until the drum is in tune again.
終わりに
作成者
2人の作成者と共同で作成されました。
Daniel Barry
メンバー登録日: 11/28/21
145 ポイント
1ガイドが承認済み
チーム
Idaho State University, Team 1-6, Watkins Fall 2021 Idaho State University, Team 1-6, Watkins Fall 2021人のメンバー
ISU-WATKINS-F21S1G6
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 6
今までの合計 180
