メインコンテンツにスキップ
はじめに
This guide will show you how to properly replace the power button on your Motorola Droid Ultra XT 1080
  1. Gently remove the SIM card tray from the device using a spudger. Gently remove the SIM card tray from the device using a spudger. Gently remove the SIM card tray from the device using a spudger.
    • Gently remove the SIM card tray from the device using a spudger.
  2. After SIM card removal press the spudger between the plastic case and the frame until you hear a snap.
    • After SIM card removal press the spudger between the plastic case and the frame until you hear a snap.
    • Work your way around the device until all the clips are released.
    • Be gentle while doing this so you don't crack or break the plastic.
  3. Remove the five screws on top of the device with a T5 Torx.
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  5. Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws. Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  6. Remove the four T5 Torx screws securing the motherboard.
    • Remove the four T5 Torx screws securing the motherboard.
  7. Gently pry the motherboard out of the frame using the plastic opening tool.
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  8. Once motherboard is removed you have gained access to the power button. Gently, using a pair of angled tweezers pull on the power button to remove it.
    • Once motherboard is removed you have gained access to the power button.
    • Gently, using a pair of angled tweezers pull on the power button to remove it.
まとめ
knoyes
メンバー登録日: 2018年10月30日
730 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G8, Peak Fall 2018 UMass Dartmouth, Team S3-G8, Peak Fall 2018人のメンバー
UMASSD-PEAK-F18S3G8
3 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 70
