メインコンテンツにスキップ
Droid Ultra XT1080 Front assembly with frame Replacement
必要な工具と部品
  1. Droid Ultra XT1080 Front assembly with frame Replacement, Front assembly with frame: 手順 1、 1の画像 1
    • Start by removing the Sim card tray, which also happens to be your volume button
  2. Droid Ultra XT1080 Front assembly with frame Replacement: 手順 2、 1の画像 1
    • I personally used an iSesamo tool to unclip the tabs off the back housing, You can also use the Jimmy or some plastic prying tools.
    • Do Not pry the back housing around the bottom of the screen. Pry on the left, right, and top. After that the back housing should slide off on the bottom.
    How do this please
    wajahat - 返信
  3. Droid Ultra XT1080 Front assembly with frame Replacement: 手順 3、 3の画像 1 Droid Ultra XT1080 Front assembly with frame Replacement: 手順 3、 3の画像 2 Droid Ultra XT1080 Front assembly with frame Replacement: 手順 3、 3の画像 3
    • T5 Torx screws
    • T3 Torx screw
    • T5 Torx screws
    • T5 Torx screws
    • When putting back together, do not tighten the screws too tight.
  4. Droid Ultra XT1080 Front assembly with frame Replacement: 手順 4、 1の画像 1
    • T5 Torx screws
  5. Droid Ultra XT1080 Front assembly with frame Replacement: 手順 5、 2の画像 1 Droid Ultra XT1080 Front assembly with frame Replacement: 手順 5、 2の画像 2
    • T5 Torx screws
  6. Droid Ultra XT1080 Front assembly with frame Replacement: 手順 6、 3の画像 1 Droid Ultra XT1080 Front assembly with frame Replacement: 手順 6、 3の画像 2 Droid Ultra XT1080 Front assembly with frame Replacement: 手順 6、 3の画像 3
    • With the iSesamo tool, or a prying tool, unclip the tabs on the left and right side of the phone.
  7. Droid Ultra XT1080 Front assembly with frame Replacement: 手順 7、 3の画像 1 Droid Ultra XT1080 Front assembly with frame Replacement: 手順 7、 3の画像 2 Droid Ultra XT1080 Front assembly with frame Replacement: 手順 7、 3の画像 3
    • Using a Spudger lift the motherboard from right to left.
    • After lifting the motherboard from the frame remove the tape, and lift the black tab with your Spudger to remove the flex cable.
    • When you place the new screen remember to replace the tape over the flex cable.
    • Before putting the mother board on remember to transfer your ear speaker from the old frame to the new one.
  8. Droid Ultra XT1080 Front assembly with frame Replacement, And you are done...: 手順 8、 1の画像 1
    • .... as long as you work your way backwards to put it back together.
終わりに
17 の人々がこのガイドを完成させました。
Ricardo Martinez
メンバー登録日: 10/19/14
751 ポイント
1ガイドが承認済み
8 件のコメント
I want to repair the scencor
Atihussan82 Hussain - 返信
I want to repair the XT1080 sciencer
Repair screen on droid ultra XT 1080
churchy dezign - 返信
I want to repair the camera on Droid turbo XT1080
King Bash - 返信
My Android 1080 screen is frozen. How can I get my photos?
Madeline Rutledge - 返信
My Android 1080 is frozen. How can I retrieve my pictures?
As long as your phone is on and working, you should be able to connect your phone to your laptop and use it as if it were an external hard drive.
Ricardo Martinez -
Any idea how the power button comes off the original frame? I bought a new frame, glass assembly but I’m suppose to bring over the camera & power button but I don’t see how that can be done…
steve - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 4,847
