はじめに
This guide show how to replace the screen of the Motorola Droid MAXX 2 smartphone.
必要な工具と部品
Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
Remove the static tape covering the two connectors.
Use a spudger to disconnect the battery cables from the motherboard.
If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
この手順で使用する道具:Tweezers$4.99
We will be removing these 3 ribbon cables.
Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
Use tweezers to lift up on the grey latch on the ZIF connector.
Remove the ribbon cable from the ZIF connector.
2 の人々がこのガイドを完成させました。
