はじめに
手順 1 に進む ↓If you're confident in your repair skills, use this guide to replace the heating coil in the heart of your heat gun.
必要な工具と部品
ツール
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
この手順で使用する道具:Tweezers$3.99
Use the angled tweezers to remove the heating coil end from the input point.
4 の人々がこのガイドを完成させました。
3件のガイドコメント
Where are the heating coil wires found?
Thomas Frye - 返信 共有
I am asking where I can find a NEW heating coil wire?
Thomas Frye - 返信 共有
There is continuity in the heating coil wire, so I believe something else is causing my problem. There is one terminal on the heating element
that has a curved, rigid, bulbous hotdog shaped component that is right close to the terminal on the heating element. I am not sure what it is.
One can be seen in the picture at the top of the page in the introduction.
Thomas Frye - 返信 共有
