メインコンテンツにスキップ
Dremel MultiPro 395 Carbon Brushes Replacement
必要な工具と部品
  1. Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Blue Caps: 手順 1、 2の画像 1 Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Blue Caps: 手順 1、 2の画像 2
    この手順で使用する道具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    購入する
    • Remove the blue caps located on either side of the MultiPro using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Carbon Brushes: 手順 2、 2の画像 1 Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Carbon Brushes: 手順 2、 2の画像 2
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Carbon Brushes Replacement, Insert New Carbon Brushes: 手順 3、 2の画像 1 Dremel MultiPro 395 Carbon Brushes Replacement, Insert New Carbon Brushes: 手順 3、 2の画像 2
    • Carefully insert the new carbon brushes into the location of the old carbon brushes using your hands.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Matthew Satton
メンバー登録日: 09/17/14
520 ポイント
2のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-5, Mathis Fall 2014 University of Kentucky Louisville, Team 1-5, Mathis Fall 2014人のメンバー
LOUISVILLE-MATHIS-F14S1G5
5 メンバー
4のガイドは作成済み
3 件のコメント
Yeah. And if you've overheated your Dremel to the point where it quits running, the brushes may be melted in place. Disassemble the two halves of the case, and push against the brushes from the inside, using the armature. After they pop free, you'll probably find that your switch has melted as well. Return the whole thing to Dremel, and if they can't fix it cheaply, they'll give you a good deal on an upgrade to a newer model. Cheers!
Tor Matson - 返信
How strongly are the brush springs attached to the carbon brushes? My brushes do not look very worn, they measure .2445" (carbon block only). However, one side the spring and the brush make contact but are not held together by anything other than the spring tension. Is this a problem?
mycle85719 - 返信
I still have approx 1.5 cans on the brushes but it has stopped working, do they need changing?
jamessteele2 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 71
今までの合計 13,449
