メインコンテンツにスキップ
Dremel 8220 Motor Replacement
必要な工具と部品
  1. Dremel 8220 Motor Replacement, Motor: 手順 1、 1の画像 1
    • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
  2. Dremel 8220 Motor Replacement: 手順 2、 1の画像 1
    • Remove the ring located around the speed selector switch by pulling apart on either side. (This should require very minimal force.)
  3. Dremel 8220 Motor Replacement: 手順 3、 1の画像 1
    • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
  4. Dremel 8220 Motor Replacement: 手順 4、 1の画像 1
    • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a spudger.
  5. Dremel 8220 Motor Replacement: 手順 5、 3の画像 1 Dremel 8220 Motor Replacement: 手順 5、 3の画像 2 Dremel 8220 Motor Replacement: 手順 5、 3の画像 3
    • Remove five 10.5 mm Torx T9 screws.
    • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
  6. Dremel 8220 Motor Replacement: 手順 6、 2の画像 1 Dremel 8220 Motor Replacement: 手順 6、 2の画像 2
    • Remove broken motor. Lift out the motor until you can see the wires that connect to it.
    • Remove the clips where the wires connect with the motor. This can be done with your fingers of a pair of tweezers.
    • You should then be able to reconnect a new motor and reassemble the device.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Shailing Santiago
メンバー登録日: 03/08/16
373 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 UMass Dartmouth, Team 2-8, Isaacson Spring 2016人のメンバー
UMASSD-ISAACSON-S16S2G8
3 メンバー
5のガイドは作成済み
3 件のコメント
Have you ever taken apart the motor? If so how?
Micky Ashey - 返信
Is there polarity correctness of the motor connections?
cal yoshikawa - 返信
Yes cal, the +ve (red) wire connects to the spade marked with a red dot.
qedelectrics - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 47
今までの合計 4,219
