メインコンテンツにスキップ
Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement
必要な工具と部品
  1. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: 手順 1、 3の画像 1 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: 手順 1、 3の画像 2 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: 手順 1、 3の画像 3
    • Pull back on the release tabs to disconnect the battery pack from the housing.
    • When installing a new battery, you may need to charge it before using it.
  2. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: 手順 2、 3の画像 1 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: 手順 2、 3の画像 2 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: 手順 2、 3の画像 3
    • Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
    • Make sure you have removed the battery before proceeding as accidentally powering-on the device while disassembling is dangerous due to the high-speed components inside.
  3. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 手順 3、 3の画像 1 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 手順 3、 3の画像 2 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 手順 3、 3の画像 3
    • Lift off the unscrewed plastic cover at an angle, away from the tip of the device.
    • Gently lift the cover. It won't take much force to remove it.
  4. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 手順 4、 3の画像 1 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 手順 4、 3の画像 2 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: 手順 4、 3の画像 3
    • Lift the tip of the motor-shaft assembly gently, then pull the assembly out.
    • The blue battery contact and the spring for the shaft lock button may pop out when you remove the motor-shaft assembly. Make sure to keep track of these pieces, as they are very small.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Michael Smith
メンバー登録日: 02/10/16
175 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 3-4, Sullivan Spring 2016 USF Tampa, Team 3-4, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S3G4
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 36
今までの合計 3,031
