メインコンテンツにスキップ
Dremel 7300 MiniMite Cordless Collet Replacement
必要な工具と部品
  1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: 手順 1、 3の画像 1 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: 手順 1、 3の画像 2 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: 手順 1、 3の画像 3
    • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
    • Press the blue button and hold it down.
    • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
    • Continue until the collet nut comes completely off of the Dremel.
  2. Dremel 7300 MiniMite Cordless Collet Replacement: 手順 2、 3の画像 1 Dremel 7300 MiniMite Cordless Collet Replacement: 手順 2、 3の画像 2 Dremel 7300 MiniMite Cordless Collet Replacement: 手順 2、 3の画像 3
    • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
    • The collet itself may be in the shaft, or come off with the nut.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Kat
メンバー登録日: 02/10/16
840 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 3-4, Sullivan Spring 2016 USF Tampa, Team 3-4, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S3G4
4 メンバー
4のガイドは作成済み
2 件のコメント
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - 返信
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 17
今までの合計 32,527
