はじめに
In the following steps you will access the electrical assembly, and remove the positive and negative wires that connect the power cord to the assembly.
必要な工具と部品
Start by removing the housing cap by unscrewing it.
Next, unscrew the now exposed collet nut while holding down the shaft lock button.
To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
5 の人々がこのガイドを完成させました。
