必要な工具と部品
Remove the four Phillips head screws that fasten the motor hub to the tube adapter.
Move the hub to the edge of the shaft so it is flush, and tighten the set screw using a T5 screwdriver bit.
The hub should fit snugly on the shaft, unable to rotate freely.
Optional- Add a drop of thread locking liquid to permanently hold the set screw in place after tightening.
もう少しです!
終わりに
