メインコンテンツにスキップ
Draining a Toilet Tank
  1. Draining a Toilet Tank, Tank Lid: 手順 1、 3の画像 1 Draining a Toilet Tank, Tank Lid: 手順 1、 3の画像 2 Draining a Toilet Tank, Tank Lid: 手順 1、 3の画像 3
    • Lift the tank lid up and away from the toilet tank.
  2. Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: 手順 2、 2の画像 1 Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: 手順 2、 2の画像 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Draining a Toilet Tank, Draining a Toilet Tank: 手順 3、 2の画像 1 Draining a Toilet Tank, Draining a Toilet Tank: 手順 3、 2の画像 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
終わりに
Most toilets retain a small amount of water in the tank after draining. To remove any excess water from the bottom of your toilet tank, use our guide for Sponge Drying a Toilet Tank.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Ron Davis
メンバー登録日: 02/17/15
31,128 ポイント
13のガイドは作成済み
2 件のコメント
I have a cracking in my toilet tank going almost the length of the tank and below water line resulting in a leak. In your experience is a sealant a good option or in reality would the tank need to be replaced in time ?
Thanks
K EVANS - 返信
It would make more sense to replace the tank, than seal any crack which would only reappear after time anyway.
John Turner -
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 33
過去 30 日: 141
今までの合計 32,082
